SOURCE: skull candy double agent headphones wont turn on
I had the same problem and realized that it was because the SD card must be formatted as FAT16 not FAT32 or NTFS.
SOURCE: How do i make my bass louder for my skull candy
Try this site:http://www.skullcandy.com/forum/faq.php You will have to ask directly as the solution will vary with the model number and what equipment you are using them with.
SOURCE: Sh=kull Candy Headphones not working...
there is a possibility that the plug is not going all the way in, in the Ipod. Have you tried using other headphones on Ipod? Sometimes the plug can become unscrewed and and doesnt fit properly. It will work on some receptacles and not in others, due to differences in tolerances.
SOURCE: Dog chew cable in half on my skull candy
Yes there are ways to splice cables together, This depends on the extent you would like to go to. if splice needs replaced near end replacement end can be bought at radio shack. You can splice wires together by striping the wires back and reconnecting them together making sure all wires are connected together and not touching one another, Twist red to red white to white and ground to ground, wrap with electrical tape each by them self use heat shrink to make it look a lot better.
SOURCE: My skull candy skullcrushers's audio jack fell out.
Simply cutt what is left of the old plug off and buy a new plug. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
