Question about Samsung RS261MD 26 cu. ft. Side by Side Refrigerator with 4 Tempered Glass Spill Proof Shelves, Power Freeze/Cool Options, LED Lighting, Compact Icemaker, Door Alarm and External Ice/Water Dispenser
Samsung model RS261MD
Had a noise develop in behind the ice maker that sounded like fan blades hitting something. I pulled the ice maker out and saw what looked like ice partially blocking some sort of vent. Took a blow dryer to melt the ice and the noise stopped but now every couple of weeks I have to do the same thing again. Whats the problem??
David Emmel
    Sergeant:
  • 295 Answers
You have a defrost issue. This link will aid you in diagnosing and parts.
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Posted on Dec 16, 2017
1 Related Answer
goodwinpeg
Peter Goodwin
  • 744 Answers
SOURCE: Samsung RF260BEAEBC ice maker stopped working for 2 weeks. It just started working again. Have no idea why. How do I diagnose the cause?
Hello James;
My name is peter. I am a retired field service refrigeration technician.
It is not uncommon, especially with the flex mold type ice makers to have a ice cub jam the operation. I have gone on many a service call to find this the problem. I suspect over a period of time the vibration of opening and closing the bottom freezer door may have jarred it loose. Your rocker arm may also have been stuck.
It is not common but possible that the ice maker water solenoid valve spool may have been stuck. I would check this by gently tapping on the solenoid valve with a tool. It may have freed itself once again over time through normal operation vibration.
Posted on Jan 09, 2015
Testimonial: "Peter...thanks for your answer. Ill give your suggestions a try."
Samsung wheezing/ Gasping sound.
It is likely just refrigerant coursing through the coils, or maybe the water valve when it opens to fill the ice maker... Is it constant, or does it come and go at intervals?
May 27, 2016 | Samsung RF4287HABP 28 cu. ft. 4-door...
How to access service Menu on Samsung Refrigerator 26Cf French model RF261 BEAE
look on the internet for a service manual from samsung and goo from there maybe it wants a new memory card fitted
Oct 31, 2014 | Samsung RF261BEAEBC 25.6 Cu. Ft French...
Samsung Refrigerator with bottom freezer model # RB195BSBB freezer will not hold temperature. There is a fan running a loud and constantly, and freezer will work it's way down to 8 degrees but will not get...
Check for ice build-up in and around the freezer fan where the blades are, if you can see ice in there (some times it may look like white foam but dont be fooled, it will be ice), the fan will be hitting it, defrost the freezer and check defrost element, (you will have to dismantle freezer section to get to it but reletively simple job) disconect from mains first. Good luck
Dec 18, 2010 | Samsung Freezers
Freezer motor running nonstop
Behind the back panel you will find the freezer fan motor. unplug and take everything out. take the back panel off and find the fan. stick something in the blade like a bannana or whatever (no rags or paper towels though) just something to jam the blade (its plastic so dont break it) replug. remove whatever you put to jam the blade and if you hear the sound then you know for sure it is the fan. got to replace fan if you want the noise to stop
if it is not the fan let me know
hope this helped
Apr 01, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
Motor noise from Bosch freezer 'noFrost' unit area sounds like a fan blade striking something on each rotation. Stops when door opened; starts and continues for several minutes when door closed.
Hi, If you say it stops when the door is opened and starts again when you close it, it is the evaporator motor in the freezer its self. The blade/prop is hitting maybe a chunk of ice or may be a part of the casing some where. This motor is 120 volts and the blade is either aluminum or plastic. You can fix this on your own if you are a handy guy, you just need to get back to where the motor is and plug it in to see what it is hitting.The bearings may be going out causing the motor shaft not to be true and hitting. You will be able to see the motor turn and know if it is straight. I don't believe that's the problem, something has moved slightly causing the blade to hit it on start up.I have seen this happen many times.Once you get the cover off, it should be a quick fix for you. Keep me posted. If it turns out to be the bearings as you will see the shaft wabbling, take it out, make sure you unplug it, an get the name Bosch, model, and serial numbers and get one at a appliance parts house. Like I said, I don't think its the bearings or it would stop working or be real noise all the time. The blade is just hitting something small. Keep me posted,
Sincerely,
Shastalaker7
Mar 23, 2010 | Freezers
Doesn't make ice cubes. Water doesn't come in.
Hello it sounds like the timer on the ice maker may be the cause. If you open the freezer when the fan is off raise and lower the arm on the ice full shut off. listen for a faint clicking noise you wont hear if fan is going. If it does not click the problem is going to be in the actual switch. I have repaired several with this same problem with the switch but you would probably rather invest in a new ice maker or either buy some trays. As the ice makers can cost up to 200 dollars in some models. The only other thing to check is if the water line is bent or crimped off.
Jan 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Fan in freezer very loud noise
There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the bottom.....you will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
Hope this helps
Feb 01, 2009 | Freezers
Fan making loud noise like its hitting against something
take and defrost the unit and make sure that the drain line is clear. this should solve it. Thanks for using FixYa.
Dec 25, 2008 | Freezers
Ice/cold room chiller fan noise
bearings in motor bad(new motor) fan blade hitting ice build up many different causes for this
Mar 29, 2008 | Freezers
Samsung RS261MD 26 cu. ft. Side by Side Refrigerator with 4 Tempered Glass Spill Proof Shelves, Power Freeze/Cool Options, LED Lighting, Compact Icemaker, Door Alarm and External Ice/Water Dispenser Logo
279 people viewed this question
Top Samsung Freezers Experts
Tad
Level 1 Expert
Harrie
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
