It beep twice while filling, it will not drain and spin
SOURCE: My ge prodigy wpse5290 won't
replace the hose that leads to the fill switch. there is most likely a pin hole sized hole in it not allowing the air pressure to build up and make contact witht the fill switch
SOURCE: GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
SOURCE: GE washer won't spin
Have you tried to blow out the air in the tube that connects to the water level switch control? Sometime that will get blocked. You will need to make adjustments here because the air in the tube determines how much water fill the drum.
SOURCE: GE WVSR1060A1WW washer will wash but will not drain/spin
Lid Switch either magnetic or mechanical
SOURCE: GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
