Question about Bosch Axxis WFL 2060 Front Load Washer
Machine does not drain - same problem as Oct 8 2007 poster
After cycle the washer will not drain. if you select the drain option the machine makes a whining noise.
  • findik Nov 26, 2007
    I have WFL 2060 which stopped draining. According to the answer given in this site to the same problem, I decided to clean the draining dump as told in the user manuel, page 20. However as seen in the picture above there exists no drain hose in my machine and I can not manage to pump cap. Is there an easy way to remove it, or should I force it using a util like knife ?
    Thanks in advance,
    Funda
Anonymous
  • 105 Answers
Pump cap screws out anticlockwise
if not been off it may have been screwed on too tight
if machine still has water in it you may have to get you machine out side other wise you are going to have a wet laundry
Posted on Jan 02, 2008
Washer making whining noise rinse cycle
Possibly a worn drive belt, or it needs tensioning.
Jan 06, 2018 | Whirlpool Ultimate Care II LSQ9549L Top...
Hi, our washing machine started making very loud banging and whining noise in the final spin cycle and the machine was shaking. We have taken off the back. The springs look ok. any suggestions?
Loud banging is usually an unbalanced load. whining noise is some times debris trapped in drain pump causing it to squeal like a fan belt on a car. Strings, threads and hoses tend to get wrapped under agitator and cause noise, too.
Jul 24, 2009 | Frigidaire Affinity ATF6000F Front Load...
Washer runs through the cycles but does not drain
Hi There,
Check the water pump and belt. Let me know if this helps.
Mar 19, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore washer makes a whining noise
The whining noise is usually caused by the pump. Try replacing the pump. Or cleaning it out.
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore washer makes a whining noise while pumping water
This is caused by the pump. Replace or clean out the pump.
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer makes whining noise on spin cycle
Check to make sure that your machine is still level using a regular carpenters level. If it is not, You may be able to level it by screwing on the legs until it is level. But carefully and not too much at once.
Aug 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer making noise in spin cycle
Is this unit new? I had a frigidaire that would really get to going on the spin cycle. Got the clothes really dry and sounded like a jet engine if no clothes were in it. Is it a whisling sound or screeching sound...The sound could be coming from the water pump. It may have something in it that is dragging. Some you can take the bottom off of and clean them out..
Feb 10, 2008 | Washing Machines
Whining noise, only in rinse and spin cycle, sounds awful.
Check the pump to make sure there isn't something stuck in it.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Same problem as Oct 8 2007 post - washer will not drain
The possible reasons and solutions for this..
1)Drain hose is kinked or house drain is restricted.
Straighten the drain hose to improve water flow to the drain.
2)
Standpipe is too high.
Standpipe must not exceed 96 inches in height.
3)
Drain hose has been taped (or sealed) into the standpipe.
Tape holding the hose in the standpipe should not form a complete seal. The standpipe needs air for proper draining. Remove some of the tape to make an air path.
4)
Drain hose fits too tightly in the standpipe.
There must be an air gap between the drain hose and the standpipe for proper draining. The standpipe needs to be at least 1 1/4 inches in diameter.
5)Also If too much of soap is used the washing machine drains slowly or will not drain at all..
Oct 22, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
122 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
