SOURCE: reset button
No reset button for a long time on any brand of tv.....
Check horiz output transistor,fuses and power supply
components........................T.
SOURCE: TV makes chirping noise, won't turn on!
That usually means a problem in the start up or deflection circuits. Diode, Horizontal ouput or driver transformer. What Chassis is this set, and I will be ableto give you some better information. Rca , GE and phillips need to be diagnosedwith the chassis number. Let me know the chassis.
SOURCE: My SANYO DS32225 32" TV wont turn on.
If the set turns on for a while, then shuts down, there is a problem internally that is being detected. The set has a num,ber of error detection circuits that will cause that shutdown to prevent further damage, You can try a "reset" if you like, but I doubt it will help. The easiest way to do this is to unplug the set for at least an hour. More than likely, the set has a number of poor solder connections and possibly defective parts. If you can solder, try resoldering any connections on the board that appear to be grainy or have rings. Update this with your results.
Dan
SOURCE: tv won't stay on. turn power on and it goes right off again.
Change cap c626 1000mf-16v to 1000mf-35v
SOURCE: stretched out tv picture
Both the TV and box have aspect buttons (although they may call it by another name) check to make sure you can control both then you'll find the right combo.
Rustym62
