This mistake code indicates a blunder inside the Boot Configuration Data. Mistake Code 0xc000000f Windows 10 springs up when you attempt to peruse BCD. At whatever point this mistake shows up, it demands you to fix your framework through Windows Installation Media. When you attempt to execute an undertaking, you need Boot Sector to stack Windows. On the off chance that some debasement shows up inside the Boot Sector, Windows will never again load. Hard Disk disappointment likewise makes this mistake to spring up. In the event that the Hard Disk got tainted by malware, it will oppose you Windows from stacking.
Solutions to Troubleshoot Acer Error Code 0xc000000f:
This 0xc000000f mistake code can be a worry for clients. Its multifaceted nature can set aside a portion of your effort to fix this blunder. Be that as it may, there is nothing to stress over. Peruse out the blog or visit Acer Customer Support to get to the underlying foundations of the blunder.
SOLUTION 1: Removal of Devices and USB Connected to PC
On the off chance that you have any outside gadget, for example, drives or USB associated with your, this blunder code develops. You have to expel all the equipment gadgets associated remotely to your Acer Laptop or PC. Evacuate your framework in the wake of isolating all the outer fringe gadgets.
SOLUTION 2: Checking of Hard Drive
As a matter of first importance, you have to embed the establishment CD/DVD into the drive.
Presently turn on your framework to pick Repair Your Computer.
Set the suitable Language, Keyboard and so on.
After you are finished with the procedure, you have to single out the Windows Installation Driver.
Select C:\ pursued by tapping on Next.
As the System Recovery Options Screen opens up, type chkdsk C:/f. What's more, in this manner hit the Enter catch.
Give the procedure a chance to finish and accordingly check whether any blunder still repeats or not.
SOLUTION 3: Use Set Up Wizard to Repair Your Computer
As a matter of first importance, you have to embed the CD/DVD. Also, hence pick the Language to Install, Time and Currency configuration and Keyboard Input Method.
Snap on Next to pick Repair Your Computer from the Setup Wizard.
Utilize the device and therefore restart your framework check in the case of all is well or not.
SOLUTION 4: Repair Your PC
Supplement the establishment media, for example, USB, DVD, or CD into the port.
Next you have to restart your framework pursued by squeezing the F2 catch.
Pick right "Boot Order" as the BIOS Screen shows up.
Set a name for your USB/pen/Drive DVD/CD and press the F10 catch to spare changes.
Reboot your framework to spare changes.
FOR MORE INFORMATION OR HELP VISIT ON GIVEN LINK :
https://www.acersupport247.com/blog/fix-acer-error-code-0xc000000f
