Question about UTStarcom CDM8630 Cellular Phone
Need to reboot
Will come on with charger inserted, says battery fully charged, but once removed goes off
1 Related Answer
Anonymous
  • 5 Answers
SOURCE: My blitz keeps saying insert the battery when it already installe
the batteries dead. you need a new one because after the battery dies it wont awknowledge the charger or battery. same thing happened to me. honestly this phone is a piece of ****. youre gonna have a lot more problems ttrust me. im having a problem with it now.
Posted on Jul 01, 2010
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Tip
How do I charge my iPod touch for the First Time
<p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
on Aug 09, 2011 | Apple iPod touch
Headset won't recharge battery must be dead
That may very well be the case. There is a finite number of charge / discharge cycles a battery can handle. This number varies based on the level of discharge prior to charging, temperature, etc. Some devices can operate via charger alone - and others require a small amount of battery power and a charger to operate. A classic tell tale sign is an older device that has been used regularly and charged every day or night - but was allowed to fully discharge once - due to failure to connect to the charger. Attempting to charge may indicate it is accepting a charge but goes completely dead / dark when the charger is removed. That usually indicates a battery that was drained so low that it will need to be replaced. Good luck!
Oct 19, 2015 | Radio Communications
It doesn't seem to keep the charge. does that mean I need a new charger or a new headset?
Sounds like the battery is not holding its charge.......you can rejuvenate the battery by fully charging and then fully draining til it goes off either by leaving on or using! Doing this a few times will allow the battery to fully charge and hold the charge better!
Feb 04, 2015 | Radio Communications
How many amps to charge a car battery?
most chargers these days regulate the amperage as the battery charges. My Motomaster charger starts off at 16 amps on a depleted or low battery and goes down to 5 amps once fully charged. Battery maintainers put out about 2 amps.
Jun 12, 2014 | Vector Black And Decker High Frequency...
I am putting fully charged battery but it is blinking red for charging the battery
I had this problem. If you have the original Nikon charger, insert the battery and press the calibration button. I dont know how, but it charged the battery fully.
Sep 25, 2012 | Canon PowerShot A470 Digital Camera
Should I remove Nicads from charger after charge
That depends entirely on the charger. Cheap chargers will not shut off power to batteries even when they are fully charged. Nicer chargers will cut power to the batteries when they are charged up.
But the safe answer is yes, remove batteries once they are done charging. (And store batteries with a full charge.)
Apr 21, 2012 | Drills
When I start up the computer it only goes to the Asus black screen and no farther. I put in the recovery disc but nothing happens. I can get into bios but not sure what to do once I get there. Help
Remove your battery completely, plug the AC cord in and try a reboot ;)
(If you leave your battery charger plugged in on a fully charged battery it may cause a voltage issue preventing your Graphics card or other things to start.)
Aug 26, 2010 | ASUS X83Vm-X1 Notebook
Sony ericsson w995 won't charge. On attempting to charge phone says "Battery can not be charged insert a Sony Battery" (the battery is the original battery) once that screen goes it says insert SIM even...
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 16, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Craftsman power drill - batteries wont recharge. When I insert dead batteries into the charger The green light ''Fully charged'' comes on and stays on. The batteries do not charge as when they are inserted...
the battery's are most likely dead, (like the real dead) after many uses of rechargeable battery's they slow stop holding charge at all, make sure when you get a new rechargeable battery you fully charge it once and fully discharge it once this will increase batterys life time
Sep 27, 2009 | Drills
UTStarcom CDM8630 Cellular Phone Logo
Top UTStarcom Cell Phones Experts
Marvin
Marvin
L Vincent Testa
L Vincent Testa
Andrew Taylor
Andrew Taylor
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
