Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Fluctuating sound - Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Posted by Elizabeth White on
shaun taylor
  • Samsung Master
  • 1,527 Answers
Hi go into the menu on the tv scroll down to sound settings select avl if on select it to off hope it helps
regards
shaun
Posted on Jan 19, 2014
Abs light and tachometer fluctuates, loss of power on 1997 taurus
What is now,any lights,any codes,sound car quit and came back.could be crankshaft sensor.
Feb 06, 2013 | 1997 Ford Taurus
Why does the volume on my Vizio tv fluctuate, and what can I do to fix it?
Doesn't work for me, turning off all sound enhancements does nothing, come still fluctuates, I feel ripped off, what a huge let down.
Sep 13, 2011 | Vizio VF550M 55 in. LCD HDTV
Eng. temp. fluctuates (cold to normal) heater
It sounds like your thermostat is stuck open, not allowing the engine to warm up enough.
May 27, 2010 | 1999 Ford Ranger SuperCab
2002 pontiac grand am, idle fluctuates at cold start in parkp0102
Sounds like a vacuum leak. Do you hear a sucking sound? Check your vacuum hoses, around the throttle body and intake for the sound. p0102 can come on when there is unmetered air getting to the engine and it could be fluctuating because the idle air control valve is trying to compensate.
Sep 27, 2009 | 2002 Pontiac Grand Am
98 bravada gas gauge fluctuates rapidly from E to
sound like a problem with your sending unit inside the gas tank with fuel pump or gauge in dash defective but with GM usually it is the sending unit
Jun 13, 2009 | 1998 Oldsmobile Bravada
Speedo fluctuates; s light comes on
it sounds like your speed sensor is going out you should replace it before it gets any worse
Jun 09, 2009 | 1991 Honda Accord
Fuel gauge fluctuates on 1995 chevrolet tahoe
make sure all connections are tight. sounds like a ground problem. or flote in tank is not working right or catching on something.
Jan 28, 2009 | 1995 Chevrolet S-10 CA Edition
Sound volume fluctuates
gah im having same problem with my creative 5.1s... took it apart and used contact cleaner on every bit of soldering i could see, and checked the wire... still no luck
Sep 27, 2008 | Logitech X-540 Computer Speakers
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
51 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
