Pride Jazzy 1103 Ultra Indoor Power Wheelchair Logo
c
chuck thompson Posted on Jan 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red and orange lights flashing chair wont move
ernest a fleming
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 105 Answers
  • Posted on Jan 19, 2014
ernest a fleming
Expert
Level 2:
New Friend:
Greenhorn:
Answers
105
Questions
0
Helped
19664
Points
116
They levers under the front of your seat is disengaged push both towards the rear of the chair ,then turn power off and turn it back on?and then try it
4 Related Answers
oregoon
  • 175 Answers
  • Posted on May 23, 2010
SOURCE: all lights are flashing, and chair won't move when I try to use
The flash codes for the VSI controller used on this chair are located here:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
These will tell you what the fault is; repost with more information.
Anonymous
  • 232 Answers
  • Posted on Oct 20, 2010
SOURCE: chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Anonymous
  • 332 Answers
  • Posted on Dec 25, 2010
SOURCE: chair was charged last night and now the power
NEW BATTERIES NEEDED TRY CHARGING CONSTANT FOR 16 HOUR IF POSS OR OVER NIGHT. IF BATTS KEEP FAILING THEN SERCH NEW BATTERIES ON THE WEB A PLACE IN WALES DO THEM NEXT DAY DELIVERY GOOD VALUE
Anonymous
  • 232 Answers
  • Posted on Dec 27, 2010
SOURCE: Battery fully charged chair levers engaged to
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
tip
Helpful Information when posting problems ith power chairs, scooters or lift...
If you are having problems with a power chair, mobility scooter or lift chair Give as much information as you can. Did Medicare pay for the mobility product? How old is the product? How old are the batteries? When you are getting flashing lights on the battery level indicator or light on scooter console. Count the number of flashes ie: 4 flashes pause 4 flashes pause etc. If the lights are scrolling are they moving right to left or left to right? As much info as you can give will help in telling what problem you are having and easier to help if possible.
In problems with lift chairs does to chair go up but not down? Will the chair move up or down at all? Do you have a red light visible on your transformer that is plugged into the wall socket?
Thanks
Lennie
on Sep 13, 2010 • Health & Beauty
What does a flashing red light on a jazzy power chair mean and it wont move
Need to count the number of flashes and consult your user manual. There is usually a section there that explains Fault or Flash Codes and will usually lead you to the problem.
If your still struggling please just message back
Thanks Dave
What does orange wrench light mean
Have your charger tested also refer to User Manual, in case you do not have one http://www.shoprider.com/usermanuals
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
4helpful
2answers
The lights are flashing and i cant get the chair to move. What should I do?
The flashing lights is a fault code. Count how many lights are flashing, and let us know, then we can tell you what the fault is. Check that both free-wheel levers are in the correct place. Good luck. Neil.
9helpful
3answers
Lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
1helpful
Power problem
Please check the connections on motor.May be they have bad connection.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
