USB flash does not appear on boot list option
1. The PC has to support booting from a USB flash/pen/key drive. There may be anywhere from 0-3 items to change in the BIOS to make this possible assuming your BIOS supports it. Some older bios's may refer to your flash drive as a USB floppy or USB zip.
2. The USB flash drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. The flash drive must have bootsector area. This is done with special utilities.
5. References to "A:" drive lines in the autoexec.bat and/or config.sys files you copy to the drive after you make it bootable may result in errors.
6. There are several programs available if you do a Google search that will help you make your USB Flash Drive bootable as well.
Posted on Jan 18, 2014
SOURCE: i have a hp pavillion
Ignore it, it just means it could run faster if you had USB 2.0 but almost all USB devices are backward compatible to standard (USB 1)
Posted on Sep 17, 2010
SOURCE: Hello, I am in a need
use window 7 installation bootable disc. that will help...
Posted on Sep 29, 2011
SOURCE: How do I get it to boot from a USB flash drive?
Hi colnewman,
I can understand it could be frustrating some times But First you need to Format your Flash Drive to a bootable disk for your computer .
I had the same problem long ago
This particular step helped me to resolve this
I connected the flash drive and format the drive using NTFS file system.
Then click on Start-> Accessories-> System Tools-> Back up
now click on the wizard and click next
There will be an option called "All system files backup in this computer".This will create an Automated System Recovery Disk (ASR) . Select the target as USB Drive.
Hope, This will resolve the issue.
Posted on Apr 27, 2012
