Common issue with AMD based hp laptops.
Before doing any of the following from this point, please remove the ac adapter and battery from the unit.
Remove the battery and try to power on with the ac adapter.
With the battery and ac adapter removed, press and hold the power button for 30 seconds to a 1 minutes. We are trying to remove all the excess power from the computer, remember capacitors can still hold power. Now power on the computer with the battery and ac adapter.
Remove the ram and reinsert the ram. Sometimes the memory somehow manages to get a bit loose overtime. Try to power on the unit and see if turns on.
Try to connect to an external monitor to determine if its hardware issue by just connecting only with power adapter. If it works, then its screen and screen connection issue. If it doesn't work, then its motherboard/video problem.
SOURCE: hp dv3 boot: no bios, blinking screen
First, remove the Battery Pack from the Notebook and reinsert it after an hour.
Also, press the F8 Key on the Keyboard while turning ON the Computer.
Next, please select "Last Known good Configuration" from the menu.
Ensure that the Booting Priority is set to HDD in the BIOS Settings and also turn OFF the Quick Boot feature. This should resolve the issue.
