Yellow LASER is bad. Its located under the yellow drum you need to replace it. You must purchase the LASER parts as (4) units one for each color but you can replace the a single unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Minolta Bizhub C353 fails scan to emails
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
SOURCE: WHY IS THERE A BLINKING ORANGE LIGHT ON BIZHUB
That is not much to go on, but it is possible that the print job got sent to the wrong tray. Say you printed a job to tray 2 which has legal paper in it, but the job is formated for letter it could lock down printing until the job is canceled and sent to the right tray. If there is an error code try and shut machine off and on using the main power switch inside front door.
SOURCE: adding an IP address to Bizhub C353
at the copier press the scan button touch direct input tab,touch scan to smb, in the host name field enter the tcpip address of the target pc, in the destination folder enter the shared folder name, in the user id field enter the valid workgroup or domain user name, in the password field enter the user password, press start. at the computer you have to create a shared folder on the root of c: and give it all rights read and write allowed this is how to scan to a shared folder you can also sca to an internal email server or to a ftp server on your network or to a usb flash drive that you can plug directly into the machine
SOURCE: what does code c-3101 mean on a bizhub c353
C3101: Fusing Pressure Roller pressure/retraction failure
hi,
open the fuser unit out of the machine and you may find that the gear which drives the fuser unit at the behind which retracts the pressure roller must have been broken. This gear is located at machine frame where the fuser sits
SOURCE: Have a bizhub C353 conected to a network. Using a
have a bizhub 250 trying to scan to pc via smb on a network. Keep getting login failure. Can you help
