Alba LDVD1538WDCH LCD TV Logo
Question about Alba LDVD1538WDCH LCD TV
Usb saying unsupported files no manual for tv
Posted by Gail Carter on
Fire tv stick unsupport
well there's your first problem right there !! fire sticks plug into a USB port not a hdmi port if your tv doesn't have a USB port then its not for using with a firestick
1helpful
2answers
USB containing MP3's is inserted but deck says "unsupported" and will not display songs. I transferred songs on an IMac to the USB if that matters.
Using an unsupported USB device can result in abnormal playback or display of the audio file. Even if you use the USB device conforming to the above specs, audio files cannot be played normally depending on the type or condition of the USB device.
: tried to play a movie via usb but it said unsupported file and the manual said movies AVI. what does AVI mean and what can I do? Thank you
As the TV reports; the file system of at the USB will be unsupported. There is no remedy for this; other than convert the file system of data in the USB, to a supported one WRT TV. Gopakumar Gopalan Google
How to get movies to work when using external hard drive
Try download a converter on the USB storage it's the tv it can't read the file
3answers
Sanyo tv avi unsupported file
Maybe you have reported that AVI and some other formats not supported by Sony TV, in this case how can we play AVI files on Sony TV from USB flash drive? Please don't worry, now we will share the best AVI to Sony TV converter - Pavtube Video Converter with you, which can help you to convert AVI files to Sony TV USB supported format, and then you can play videos on Sony TV with compatible format.
Reference: Watch MP4/AVI/MKV Files on Sony TV from USB
2answers
Invalid or unsupported file
Check the TV manual for which movie file format will run from the USB port on the TV.
You may need to convert your movies to a file format the TV uses.
Check out this WEB site for video file conversions.
http://www.fixya.com/support/r5874192-play_videos_mp3_player
Unsupported usb
Windows has a 2 TB MBR limit. So, I expect the TV does as well. What that is?
You need to ready new hard drives by formatting prior to use, and in your case partition as well.
1helpful
2answers
Canot play media on television from Hitachi 500GB Touro Mobile USB 20
Check the supported movie files that can be played on that tv then look at the file and see what type of file it is. I recommend using MP4, WMA or AVI files
How do i get a movie on a USB compatible to work through my set top box, it says it is an unsupported file?
It i saying unsupported file because the format is not compatible u need to convert the file into the format which is acceptable.Look at the manual for the format which is compatible and then convert the file into that format.There are thousands of sites through which u can convert ur movie.
Thank you.
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
