Question about Kyocera FS-C5030N Led Printer
Open the fuser for FS-C2126 MFP
WE HAVE A STUCK PAPER IN HERE!, IT SAYS TO OPEN TH FUSER BUT, WE DONT KNOW HOW.. please explain me how to open the cak fuser and take out the stuck paper
Posted by daniela on
donovin mclain
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 210 Answers
There is a blue mark on the right side of the fuser simply pull it towards you and that should allow you to see the rollers and remove paper if not its four screws and three connectors to remove the whole fuser
Posted on Feb 18, 2014
  • donovin mclain
    donovin mclain Feb 18, 2014
    on the fusers right side you should see a blue mark just pull it towards you to show the rollers and remove the paper
  • philip b
    philip b Jul 10, 2014
    awesome ... thanks a million
5 Related Answers
Anonymous
  • 56 Answers
SOURCE: grinding noise and jamming
Try to pull out paper transport unit (when open paper cassette,there is green or blue andle on the printer) and check what is wrong.Maybe just something is in improper position.
Also check paper settings on printer and driver.
If you use 80-90 gsm paper-Plain, if You using heawyveight paper(more than 105 gsm untill 200gsm) -Thick.
BR
Posted on Dec 06, 2007
justin
  • 58 Answers
SOURCE: Kyocera Mita 4230
replace the conveying belts x 3 2ac??? part number and maybe worth replacing clutch 32&35 resistance clutch
Posted on May 01, 2008
Anonymous
  • 25 Answers
SOURCE: Kyocera FS 9130DN is showing
check the bypass transport connector for a small piece of paper. or the paper sensor arm is jammed down there are 2 one in the transport unit and one in the mp tray
Posted on Nov 04, 2008
Anonymous
  • 241 Answers
SOURCE: Kyocera FS - 3900DN creases the paper
If even a very small piece of paper is in the paper path it could cause this issue. You may need to have a technician take the printer apart to see what the cause is. If you can indicate exactly where inside it may be causing the paper to crease it would indicate whether one of the rollers is causing the issue or not, you may have a roller that is needing to be replaced. If you haven't had your printer looked at by a technician in a while it may be time to get a maintenance cleaning done which would resolve your issue and also indicate if there is any major problems going on with your printer.
Posted on May 28, 2010
Brian Achterberg
  • 62 Answers
SOURCE: Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Posted on Jul 07, 2010
Can you use a Kyocera FK-170U fuser unit in place of a FK-150 fuser unit?
No the FK-170U fuser will not work in a printer that is compatible with the FK-150 fuser unit. I found a Kyocera FK-150 Fuser Unit available on Amazon here: https://www.amazon.com/Genuine-Kyocera-FK-150-302H493032-Kyocera/dp/B00GOO57M2 . Other sites have third-party replacements.
The FK-150 fuser is the correct fuser for the FS-1028MFP, FS-1128MFP, FS1350DN, among others. The FK-170U fits the following Kyocera printers: FS-1035 Mfp, FS-1135 Mfp, FS-1370DN and FS-1120D. There are a few other printers. The design changes means they can't be substituted.
I hope this helps.
Aug 01, 2018 | Kyocera Office Equipment & Supplies
I have recently had a paper jam in my HP Laserjet 100 color MFP M175a printer.getting the error message "jam in output bin. Open rear door and clear jam"
You should check inside the fuser at the back of the printer. Probability is that there is a folded sheet or fragment of paper still in the fuser. It may be readily accessible in which case open the tensioning clips either side and carefully pull the offending item free. If you can't get at it, the fuser may need to be removed and dis-assembled.
Oct 25, 2017 | HP Office Equipment & Supplies
How do I clear the memory on a ECosys FS-C2126 Copy/printer
it is under mode 21, you need to login first to maintenance mode by punching the numbers 1087 1087. then select the number 21 then hit start. you will be able to clear the memory .
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Jun 10, 2015 | Copystar Kyocera FS-C2126 MFP Color...
NOISES DURING COPYING
open rear cover and check the fuser to see if there is wear on the heat roller, if there is a line worn in the roller and it makes a grinding noise,
it will need the fuser replaced, also it may need a firmware update.
Apr 02, 2014 | Copystar Kyocera Fs-1135 Mfp Multifunction...
How to open the fuser
You will need to open the cover on the rear of the machine to gain access to the fuser unit.
Jan 17, 2014 | Copystar Kyocera FS-C2126 MFP Printer
What is "fuser door open"
Fuser Door Open is the message on the display when it's powered on. I took the back apart, removed the fuser, looked all over. I couldn't see any kind of sensor, optical or mechanical that makes when the door is closed. There's an access plate with a blue latch below the fuser that makes an optical sensor and a mechanical sensor, but that seemed to be OK. It didn't seem like something that would be called a fuser door. So, I pushed on it where it made the mechanical switch and the printer hummed to life and the message went away. I took the fuser out and examined it. The metal brackets where the pivot parts were, seemed a little bent. I straightened them out, stuck it back in and that fixed it.
By moe who hasDell MFP 1850DN this might also help...
or Fuser Door Open
1. Make Sure the Paper Tray is Loaded Correctly With no Obstructions
2. Clear the Paper Jam in Tray 1 or 2
3. Clear the Paper Jam in the Multi-purpose Tray
Jul 05, 2011 | Dell 1815dn All-In-One Laser Printer
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Sep 03, 2010 | Xerox Phaser 6110 Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Samsung scx4216
Open heat error, you have a fuser problem, replace fuser. Fuser consists of Upperheat roller, lower heat roller, exit claws/rollers, and a heating circuit with a lamp, thermal temp sensor (thermistor) and a thermal fuse/cutout.
You could measuring fuser removed from machine, checking lamp etc for open circuit, thermistor should be neither short or open circuit.
These days we dont, we just change assembly due to it being a common constantly wearing part, and if for example I pull it apart, fix the lamp, put it together then soon enough I will need to pull it apart again to fix worn roller etc.
I could give you the part number ... JC81-01690A but dont use it, cause that part is for 220volt cause thats what we use in Oz, so contact Samsung and ask for dealer in your country who can supply you.
P.S. Fuser is the Hot bit (180 deg c) at back near paper exit that bonds(melts) the print into the paper.
Nov 14, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Kyocera FS-C5030N Led Printer Logo
133 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Timothy Van Der...
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
