Question about Panasonic PT-53WX54 53" Rear Projection HDTV
PT-53WX54 53 in. Rear Projection Lamp replacement
Can anyone tell me what part or parts I need to replace the lamp on this model and where I can find step by step directions preferrably with step by step pictures?
Posted by bjohnston12 on
  • bjohnston12 Oct 23, 2007
    O.k. the what if anything should be replaced to re-energize the picture?
  • bjohnston12 Oct 24, 2007
    what I mean is the picture is not as bright and not as sharp as it used to be. It certainly dioes not look like it did when I bought it. Is there a way to bring it to like new condition.
Dewayne Turner
  • 87 Answers
This is a CRT model set.  There is no lamp to replace as there would be if it was DLP or LCD technology.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
  • Dewayne Turner Oct 24, 2007
    I don't know what you mean by "re-energize the picture".  More information is needed.  Is the screen lit?  Do you have audio?  If the screen is not lit do you have on-screen display when you hit the menu button.  If the screen is lit do you have a full screen?  If you have a picture what does it look like?
    It is possible that the mirror and lenses are very dirty and just need to be cleaned.  To do that you would need to remove the front screen assembly.  Usually you have to remove the speaker grill.  Sometimes these are simpy attached with velcro and if so they just pull off.  Sometimes there are screws from the back that holds the speaker grill on.  I think on this model it is held on with velcro.  If so put your fingers on the sides of the speaker grill or the bottom and pull it off.  When the speaker grill is off there are screw at the bottom of the screen assembly that need to be removed.  There may be plug in cables attached to the switch assembly at the bottom of the screen assembly.  If so unplug them and lift up on the screen assembly to remove it.  Use a soft lint free coth and amonia free window cleaner to clean the 3 picture tube lenses and the mirror.  If these are very dirty you will see a significant improvemnt in you picture quality after they are cleaned and everything is reassembled.
I need to change the light bulb in my DLP TV. Where can I call to have someone do this?
You do not have to call anyone, this is a customer replaceable part and is fairly easy to do.
You can buy the lamp on the internet--get one from Samsung. Let me know model number---lamp is either at the back of the set or one side and the owner manual will tell you where.
I am willing to help you replace the lamp--it is a ten minute job and you should not have to pay someone to do it.
Usually all that is needed is to remove the door that covers it (one screw) and remove the two screws that hold it in; there will be a handle on the lamp housing and you just pull it out, insert the new lamp and put the screws back, the door back and bingo you are in business.
Let me know if you have questions and if you give me the model number (it is on the right side of the set and on the back of the set as well) I will get you a part number and tell you how to find it on the internet--most places like Samsung will ship it fast and give a warranty--do not buy a generic lamp--they are no bargain.
The lamp was meant to be replaceable by the customer and is easy to do.
let me know the model number and if this information has told you something you did not know rate this solution as "very helpful" as I do this here for free.
I am here to help you, let me do that.
REGARDS, SD TECH
Aug 11, 2010 | Samsung Televison & Video
How do I change the lamp? Lamp came with no directions. This is a HD72.
Hello there,If your movie projector light bulb has stopped working, there are some simple steps to take to get your movies playing again. The hardest part may be finding the correct replacement bulb. There are so many different models with their own specific bulb. Here are some steps to follow to replace your burned out light bulb.
  • Locate the bulb in the movie projector. You may need to use a screwdriver to open the bulb compartment. Check your owner's manual for proper procedures.
  • Step 2.Remove the movie projector light bulb or lamp. The bulb must be cool before you take it out. Use a tissue or cloth to remove the bulb because the glass bulb is very fragile. Do not throw away your bulb yet, you may need it to help find a replacement.
  • Step 3.Find replacement bulb. The Better Lamps website offers a wide variety of light bulb models. From their homepage select the brand of movie projector you have and using the model number from your old bulb, buy a replacement.
  • Step 4Replace the movie projector lamp or light bulb. Do not touch the bulb with your skin. This can transfer oils from you onto the bulb resulting in a hot spot which can make the bulb burst. Use a tissue or cloth to handle the new bulb to screw it back into place and then replace the cover.
  • Jul 31, 2010 | Optoma HD70 DLP Projector
    Replacing lamp need directions
    Step one: Turn off the set and let it cool down.
    Step two: There should be an access panel saying lamp on the back
    on the cover. You will need a phillips or flat bladed screw
    some models are different.
    Step three:Be sure you take out of the screws that are holding the
    lamp. I know on RCA there are about two holding it place.
    Step four: Carefully pulled the lamp out and put the new one in it.
    Make certain that you screws the lamp screws down not to
    over tighten .
    Step five: Put the lamp cover back on, plug the set in and let it boot up
    you are back in business.
    Aug 18, 2009 | Panasonic PT-60LC14 60" Rear Projection...
    Minolta EP2100 Copier - Error Code C5
    Mite try amozon/craigs list for parts, The machine is legacy system
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
    Jun 15, 2009 | Konica Minolta DiALTA Di200 Copier
    Our samsung HD TV turns on but there is no picture or sound
    if this keep flashing u need to replace the lamp and ballast , u can get this part by model number and is beter if u can get it directly from samsung
    Jan 17, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
    Mitsubishi Lamp is OUT
    Replacing the lamp is as simple as it comes. Consult your owners manual for step-by-step instructions. It's designed for the customer to change.
    Dec 16, 2008 | Mitsubishi VS-60805 60" Rear Projection...
    How do I replace Lamp in Mitsubishi big screen
    You can get the service manual for your model for 12.99 at the following link. It has all the diagrams and procedures that you are looking for to service your set. They also provide free support with the service manual to help you with your repairs. They will also email the service manual to you if you return to the site and request it. Here is the link,
    http://servicemanuals.vstore.ca/
    Jan 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
    Oven Halogen Lamp
    It's pretty simple to replace the light without having to remove the oven from the wall...as long as you have an offset phillips screwdriver...
    Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
    STEP-BY-STEP:
    First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
    Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
    Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
    That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
    Doug
    Aug 04, 2006 | GE Advantium SCA1000H Convection /...
    Panasonic PT-53WX54 53" Rear Projection HDTV Logo
    127 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Ekse
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
