Hi, my Adora 55N dishwasher is stuck and will not stop signaling and it tries to wash but will not.
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Posted on Feb 16, 2008
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Posted on Dec 13, 2008
SOURCE: Dishwasher stuck in wash cycle
see this causes and fix it. God bless you
.Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the
breaker for at least 5 minutes if this does not correct the problem you
will need to replace the timer /electronic control
Posted on Oct 17, 2012
Dec 02, 2014 | GE Adora Dishwasher. Built-In Tall Tub...
Dec 25, 2009 | General Electric Adora GHDA670N Built-in...
Aug 05, 2009 | General Electric Adora GHDA670N Built-in...
Jul 15, 2009 | General Electric Adora GHDA670N Built-in...
May 25, 2009 | General Electric Adora GHDA674N Built-in...
Apr 24, 2009 | GE Adora GHDA656LSS Stainless Steel...
Oct 02, 2008 | General Electric Adora GHDA670N Built-in...
Jan 31, 2018 | GE Dishwashers
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Oct 26, 2007 | Dishwashers
20 people viewed this question
