Question about GE Cooktops
Knobs misaligned on new GE Cooktop
We just purchased a new GE gas cooktop and after installation we have noticed that a couple of the knobs are misaligned - meaning that on one side they are very close to the numbers and on the other side there is a 1/2 gap between the know and the numbers. In one case there is a flange showing that should be covered by the know, but due to the misalignment the flange is visible. Can I pull the cooktop out and align the knob mechanism that is under the cooktop so the knobs will line up properly?
Posted by bpyurek on
Strech
  • 1,562 Answers
Most of these knobs just pull off.
If yours is like this, just pull off the knob, and reinstall by pushing back onto the shaft with it correctly aligned.
Posted on Jan 17, 2014
5 Related Answers
Joe Hogan
  • 10865 Answers
SOURCE: Can't remove Dacor gas cooktop knobs-afraid too pull harder
The Dacor knobs have a history of breaking easily. For that reason I recommend that you clean them in place using cotton swabs, tooth brush, etc. WHatever cleaning agent you use, put it on and let it sit for 5 minutes to loosen up any grime.
They do pull off but they often break and they are pricey to replace.
Please rate my answer.
Posted on Feb 12, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: I cannot REPLACEMENT KNOBS fOR model # 5D02
Hi, The part #74009592 for your knobs. This # is for a black knob. Let me know if I can assist you further.
Vic
Posted on May 24, 2009
Anonymous
  • 30 Answers
SOURCE: KNOBS WON'T TURN
if the knobs wont turn, the cooker needs to be serviced by a gas engineer the gas taps are seized they need gas tab grease
Posted on Aug 21, 2009
Anonymous
SOURCE: I'm looking for replacement knobs for my Jenn Air
I agree...the knobs are a POS.......redesign needs to happen....
Posted on Nov 27, 2009
erica graber
  • 530 Answers
SOURCE: GE profile gas cooktop - sparker firing with knobs turned off?
replace your spark module
have you spilled liquid on the cooktop recently?
if yes let it dry for a couple of days and see what happens.
sometimes when you spill liquid on the cooktop it grounds out the spark module and it will continue to spark until it drys.
let me know if you need more help
Posted on Feb 15, 2010
After spraying stainless steel cleaner on the cooktop, with the knobs removed, the igniter won't stop ticking as if it's trying to ignite. All the knobs are securely in the off position. Could this be...
Yes, the moisture is probably the problem...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Jan 21, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
We have a ge cooktop (gas). even though the knobs are turned off , we can hear "tick tick" noise from one of the burners.
Unplug your cooktop for 24hrs and retest. Sometimes moisture gets into the switches under the knobs and can cause a short. If this continues after you let the unit dry out then your will need the replace the switches/or switch harness.
Hope that was helpful please rate me a "4" if that helped.
Dec 13, 2010 | GE Cooktops
One of my cooktop knobs won't activate the ignitor
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Mar 28, 2010 | GE 36 in. JGP628 Gas Cooktop
Sparkling sound can be heard continously on the GE Cooktop
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Feb 17, 2010 | Jenn-Air JGC8536 Gas Cooktop
Feb 15, 2010 | Cooktops
Hi I have a kitchen aid cook top and need to replace the gas knobs part #KIP5692-3182567 Can you direct me on how to purchase four knobs. Thanks Frank
hi frank
goto appliancepartspros.com
or call 1-877-477-7278
your looking for part number
AP3140295
thay run around 10.00 bucks a pop
hope this helps
Oct 16, 2009 | GE JGP930SEDSS Gas Cooktop
KNOBS WON'T TURN
Aug 19, 2009 | GE Cooktops
Jenn air jgc9536
yes , but that could be the manufacturers design or the wrong knobs
Oct 18, 2008 | Jenn-Air 35 in. JGC9536 Gas Cooktop
Gas Flow
suspect problem is with the regulator on the gas bottle as it would be unusual for all burners to be faulty at the same time. try substituting a new regulator
May 18, 2007 | GE 30 in. JGP337 Gas Cooktop
Cooktops Logo
202 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
