Question about OKI C Office Equipment & Supplies
C711 blurred images
This is a new printer and has been installed as per the install doc; however when we print documents the text appears ok, but the images are blurred.
Posted by Stuart on
eselec
    New Friend:
  • 58 Answers
One ore more color ink cartridge are bad
Posted on Jan 17, 2014
5 Related Answers
Anonymous
  • 135 Answers
SOURCE: printing black squares in word.doc
It sounds like this is an HP driver issue. HP drivers have built-in "optimizations" (that unfortunately have bugs) for things like printing photos. Different programs (word, for example) try to take advantage of these optimizations in different ways. When they work, they give superior photo printing (faster, with more accurate color). When they don't, you get black squares. This is why "converting" it to PDF worked for you -- Word printed it through the PDF driver instead of the HP printer driver, then when you printed the PDF file, that program avoided those optimizations when it sent the images to the printer. Unfortunately, the translation caused quality loss. If your goal was to print out something like a "proof-sheet" of photos, you might try the free photo organizer at www.preclick.com. It will print these for you, captions and everything, and should be able to avoid the driver issues.
Posted on Apr 11, 2007
Anonymous
  • 42 Answers
SOURCE: test print great, document printing blurred
try to heat up the printhead of the cartridge on hot water about 90degre celsius and clean the head whit a clean soft paper (toilet paper is great and cheap) and make a clean nozle on the printer software.
Posted on Oct 22, 2007
Anonymous
SOURCE: Canon MP210 with Mac OS X 10.4.11 problems with printing docs
Hi
I have OS-X 10.4.11 and had the same issue; any printing just spat out blank pages.
I installed the following driver which completely resolved the issue:
http://software.canon-europe.com/software/0029270.asp?model=
There's a similar one for 10.5 that I haven't tested, to be found here:
http://software.canon-europe.com/software/0028432.asp?model=
If you use 10.5 and this driver works for you, please let others know by posting here, too.
Good Luck
Draqul
Posted on Dec 22, 2008
Anonymous
  • 62 Answers
SOURCE: printer document in queue will not delete
1. First, try turning printer off and on.
2. Next, on the computer side, this is how you manually clear the printer queue.
1. Go to Start, Control Panel and Administrative Tools. Double click on Services icon.
2. Scroll down to the Print Spooler service and right click on itand select Stop. In order to do this, you need to be logged in asAdministrator. At this point, no one will be able to print anything onany of the printers that are being hosted on this server.
3. Next you need to go to the following directory: C:WINDOWSSystem32spoolPRINTERS.Delete all the files in this folder. This will clear all print queues(it’s a good idea to first make sure there are no other print jobsbeing processed on any of the other printers on the server becausedoing this step will delete those jobs also)
4. Now you can go back to the Services console and right-click and choose Start for the Print Spooler service!
You can also go to a command prompt and type net stop spooler or net start spooler to start and stop the service.
I hope this helps. If you have more questions, let me know.
Posted on Jan 09, 2009
Patrick Kam
  • 88 Answers
SOURCE: printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Posted on Mar 20, 2009
I need to know the settings on the hp photosmart c7200 printer I should be set for me to get the absolute clearest scans of docs and also my drivers license
Hi. Here are the specs of your printer or simply follow this link to know more.. http://www.shopping.hp.com/shopping/data_sheet/cc567a.html
Print specifications -Up to 1200 x 1200 rendered dpi black when printing from a computer -Up to 4800 x 1200 optimized dpi color when printing from a computer and 1200-input dpi -Print speeds vary according to the complexity of the document -Panorama-size printing -Method: drop-on-demand thermal inkjet -Language: PCL3 GUI -Duty cycle: Up to 3000 printed pages per month
Copy specifications -Copy resolution up to 4800 x 4800 -Digital image processing -Up to 99 copies from original (varies by model) -Zoom to 400%, fit to page (varies by model) -Copy speeds vary according to the complexity of the document.
Scan specifications -Image editor included -Integrated OCR software automatically converts scanned text to editable text (if installed) -Twain-compliant interface -Resolution: up to 4800 x 9600 dpi optical (varies by model); 19200 dpi enhanced (software) -Color: 48-bit color, 8-bit grayscale (256 levels of gray) -Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
May 06, 2011 | Office Equipment & Supplies
Tip
How to conserve color ink when printing only text documents.
First, make sure you have an updated driver installed in your computer. Visit http://support.epson.com for updated drivers.
To select black ink only mode and conserve color ink when printing only text documents, please do the following:
1. Open the Printers window by following the appropriate steps for your operating system:
In Windows 2000: Click START > SETTINGS > PRINTERS.
In Windows XP: Click START > CONTROL PANEL > PRINTERS AND FAXES or PRINTERS AND OTHER HARDWARE. (Select VIEW INSTALLED PRINTERS under PRINTER TASKS if no printers appear.)
In Windows Vista: Click START > CONTROL PANEL > HARDWARE AND SOUND > PRINTERS.
2. Right-click on your printer name and select PRINTING PREFERENCES.
3. Click the ADVANCED tab.
4. Select the BLACK INK ONLY option.
5. Click OK.
Remember to repeat these instructions and remove the check from BLACK INK ONLY when printing photos or color images.
on Nov 06, 2008 | Epson Stylus Multifunction Printer/...
Ink cartidges are all installed and registering ok. New balck ink installed but will only print in colour and not black print what can I do as I need docs printed urgently?
Does it take (pull up the paper) in the paper? If so, Try to print only images and check if it works or not. It'll be much easier if you let us know the program from which you are printing. Also try to print only in text using Ms Word, wordpad or notepad. If possible update your driver. Good luck.
May 26, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Prints PDF documents VERY slowly (4-5) per page
The actual issue you will find that its not so much the actual printing part of the process that is slow, its actually the spooling to the printer that takes the time.
Does your printer support PostScript printing ? (PostScript is a printing & imaging standard used by many printers) To find out if your printer does indeed support this either refer to your manufacturers documentation or perform a test page and look to see if you have a PostScript enabled option.
If your printer does support PostScript, make sure you are using its PostScript printer driver, most of the time we generally use PCL drivers, so simply change this.
Regards....
If you find your printer does not support PostScript there are a few other tweaks we can implement to increase printing speed.
Firstly we can force PDF files to be printed as graphics as opposed to text, to do this launch your chosen PDF viewer, select Print > Advanced > Print as image
Lower the print resolution, if we lower the print resolution most of the time the difference is very small, but it can reduce the actual print size of the document by up to 300%, which can greatly decrease printing times.
Make sure you are using the latest version of any print drivers or your chosen PDF printing program, normally Adobe Acrobat.
If the printer only has a small amount of memory if possible add more, if possible install a PostScript SIMM.
Check the amount of ram your computer currently has, check memory usage from task manager when printing to ascertain usage
May 19, 2010 | HP Color LaserJet 2600n Printer
My new epson r230x printer is printing text and images blur
pls download the latest drivers software version of the printer that you use... then after that reinstall the old drivers software that you install previously.
Mar 02, 2010 | Epson STYLUS R230 InkJet Photo Printer
How can I Convert my Image Files to Text Files? i have an Image file and i want to convert it to Doc. or Text files
hi...!! if your image files are pdf file, then you'll hve to install "pdf to text file" software in your pc. then after you will be able to convert your image file to text doc....!!
all the best
Oct 10, 2009 | Equisys Zetafax Document Conversion Add-On...
Printer output has shadows, blurring, streaks, lines, poor color
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Problem using OCR with Canon MP610 all-in-one
I got this message too, before I installed an OCR program. It may be that you need to install one (or specify it, if you have one already). With my MP610, an installation disk was included that contained the OmniPage SE program for OCR. When I installed that on my computer, and told MP Navigator (another Canon-supplied program, that controls scanning) to use it as the "Open With" program for OCR, it worked.
Dec 15, 2008 | Canon MP610 Photo All-In-One Printer
HP OFFICEJET PRO K5400 - COMMISSIONED FRIDAY OCTOBER 17 1) TODAY OCT 21 PRINTING PDF DOCS TEXT WITH COLOUR PICS, PRINTED SEVERAL COPIES OK, PRINTER STOPPED PRINTING THE PICTURES. AFTER SEVERAL ATTEMPTS...
Try this !
in the software application you are printing from
Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
Look for a Best Mode Setting
this printer has several modes one being draft mode, another one best mode
in best mode the printer uses memory to render the photo you are trying to print.
Note that in this mode, printing takes
longer and more memory is required from your computer.
from page 17 of the hp k5400 user manual
Also you may have to increase the virtual memory of the windows pc to allow the computers hard drive to allocate more hard drive memory to the memory swap file if the computer's ram is not enough to print the photo.
It is a setting in the control panel under system - performance.
May 12, 2017 | HP Office Equipment & Supplies
Document printing blurred
You may have some custom print settings active. Go to the print properties and set the printer to default print settings. You may try downloading and installing the newest print drivers too. http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=257&modelid=10236 here is the canon site for your machine. Let me know what happens Good Luck, Tim
Mar 14, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
265 people viewed this question
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
