Question about LG VX6000
Forgot lock code Kyocera kona - LG VX6000
Posted by Kim k on
Kyocera Kona cell phone suddenly stopped responding to keypad, have powered down for 10 min., pwr up, same problem. rings on incoming call, can't answer.
Most likely your cellphone has a damaged keypad it will need to be replaced I don't think it's worth more than 50 bucks just replace it
How can i factory reset my kyocera kona phone without the lock code? I can not remember my code lock numbers.
Yes. You can do a hard reboot but holing down the volume down while holding the power button down (from the off state) to reset the phone to factory condition. You can find a YouTube video on this.
How to unlock kyocera flip phone when I forgot code
Hi Tammy Townsend,
If you forget the screen lock password the hard/factory reset should help. But it will wipe down all data. How to hard reset KYOCERA phone HardReset info
If you need unlock code you can try https://www.mobileunlocked.com/kyocera
Wave. How do I unlock if i forgot lock code?
How to Unlock Kyocera Phone - YouTube
? 2:37
https://www.youtube.com/watch?v=MiYN7aIbyNU
Feb 6, 2015 - Uploaded by iTech Unlimited: Unlock Codes For Cell Phones
Link https://www.itechunlimited.com/unlock-kyocera.html Unlock Code for ... i was going crazy to find a place to ...
Unlock Kyocera, Network Unlock Codes ' Cellunlocker.Net
www.cellunlocker.net/unlock-kyocera.php
Unlock Kyocera - Get Kyocera Unlock Codes Below ... Watch Exactly How we willUnlock your Kyocera Phone's Network ... Network the Kyocera is locked to.
Unlock your Kyocera via IMEI number with doctorSIM in U.S.A.
Forgot my 4 digit lock code on my Kona S2150 cellphone model
How to unlock phone on the Kyocera nano flip phone with a lock code
May 27, 2013 • Cell Phones
2answers
Error codes of my kyocera KM 1635
c3100 is a scanner home position error, does the scanner move when turned on with lid up? if not its the motor, if it moves then it mat be a sensor (usually "U" shaped in rear left under glass, or it could be "locked" for shipping, look for a switch on left side or under scanner unit. hope this helps.
2helpful
Forgot password
Call your provider.
http://cellphoneforums.net/kyocera/t300785-i-forgot-my-lock-code-kyocera-melo-s1300.html
http://forums.wirelessadvisor.com/kyocera/14612-codes-for-kyocera.html
Open Questions:
LG VX6000 Logo
Top LG Cell Phones Experts
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
