Question about Whirlpool LGB6300 Gas Dryer
Ggq9800lw1 high frequency noise
I have a high frequency noise problem only when the flame is giving heat.
Subwoofer makes noise like an untuned TV regardless of volume knob
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
Jan 18, 2014 | Cambridge Audio Minx X300 - Powered...
The heat exchanger is burning due to high limit saftey stat. What should I do
The high limits are designed to shut the heater off if the water temp exiting the heat exchanger gets too high. One is set at 135f the other at 150f. The thermostat should shut the heater off once the pool water gets to temperature.
I'm not sure what you mean by "burning". The operating temp in a 400K btu heater is around 2000 degrees. If you are getting a lot of "sooting" that is typically caused by low gas supply. That's where you get orange flame instead of blue flame. Can you give me more detail?
Nov 23, 2013 | Pool & Spa
Please help 1999 Thermozone 60,000 BTU furnace 3-stage
No it will cause the flame to burn yellow and soot up and give off co2 replace now .
Mar 24, 2017 | Heating & Cooling
What are the specifications for audiobahn a2200hcx amplifier
The specs are as follows:
RMS Power Rating:
200 watts x 2 chan. @ 4 ohms
400 watts x 2 chan. @ 2 ohms
800 watts x 2 chan. @ 1 ohm
• Bridged:
400 watts x 1 chan. @ 4 ohms
800 watts x 1 chan. @ 2 ohms
1600 watts x 1 chan. @ 1 ohm
High-Current, Non-Regulated Power Supply
Preamp Outputs
Cobalt Blue LED Illuminated Heat Sink Design (on/off switch for your preference)
Thermal Regulated, Air Induction Dual Cooling Fans
Double Sided PCB (Circuit Board)
High Gloss Chrome Plated Finish
Unique, Clean Chrome Fire/Flame Design
Blue Illuminated VU Meters Indicating Output Response
Clear Power and Speaker Connectors
Variable Bass Boost: 0-18dB @ 40-100Hz
Variable Low-Pass Crossover: 40-120Hz
Variable High-Pass Crossover: 50-750Hz
Variable Subsonic Filter: 20-50Hz
Signal-to-Noise Ratio: 100dB
Frequency Response: 10Hz-40kHz
THD: 0.05%
Channel Separation: 50dB
Apr 15, 2011 | Car Audio & Video
I have a Whirlpool Dryer. Model No.GGQ9800LW1. Dryer runs but does not get hot. I have replaced Flame sensor and the ignitor. what could it be?
Hello & Welcome to FixYa
As you have already replaced both flame sensor and ignitor & the problem is not solved so the problem is with the thermal fuse/thermostat going bad. Both these parts can be checked with a voltmeter for continuity. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Dryers
How do i turn off the high pitched frequency noise
If what we are talking about here an old model of monitor that has a bulky back, the high pitched frequency is caused by other electronic devices such as your speakers.
- Relocate your speakers away from the monitor
- do a factory reset on all settings on the monitor or if possible, do a degauss.
Dec 16, 2009 | Computers & Internet
High Pitched Ticking Noise
Horizontal output transistor is shorted,caused by bad flyback
transformer.If you want to pursue the repair,please give the
service number off back......I will get part # s........T.
Oct 25, 2007 | RCA F36705 36" TV
Whirlpool LGB6300 Gas Dryer Logo
Top Whirlpool Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
