Question about Mitsubishi WT-46807 46" Rear Projection Television
Mitsubishi hd 1080 t.v has blurry and red screen
5 Suggested Answers
6ya staff
SOURCE:
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: mitsubishi ws 55819
Bad convergence ic and should replace caps also
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Posted on Jan 16, 2008
MATT BECKER
  • 301 Answers
SOURCE: Mitsubishi 1080 hd
check and re-solder the connections on the 2 convergence ICs in the middle power board. they are going to be attaches to the biggest heat-sink in the tv. if the re-soldering doesn't fix then replace with STK392-570 i would replace both but if you look at the board you should be able to figure out which chip is responsible for the vertical and which is the horizontal convergence. each IC converges all 3 colors but one is responsible for one axis.
Posted on Feb 20, 2008
ladywinn
ladywinn
  • 5138 Answers
SOURCE: what universal remote control is
Call Mats Electronics they will have what you need 1-800-628-1118
Posted on Sep 15, 2010
hardrocko
Kim Yearick
  • 1476 Answers
SOURCE: I have a Mitsubishi 55" 1080 HD TV with a blurry
info16939,
You need to go to my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Dec 15, 2010
The screen shield of my mitsubishi HD 1080 diamond projection tv is scratched and shows rainbow color dots in some places. What can I do? Can I fix it? Replace it?
The outer screen on most models is clear and called a protective screen and prevents glare---if it has that it has 2 more screens behind it.
Getting at the outer on is not so easy---the entire frame for the screens has to be removed, the inner screens removed to get at the outer screen to remove it (if 3 screens you can do without the outer one except if it got scratched before--next will be the next screen behind it.
Check with mitsubishi to see if the screen that is damaged is available or not.
Oct 29, 2012 | Mitsubishi Televison & Video
info16939,
hardrocko
Dec 15, 2010 | Mitsubishi WS-65313 65" Rear Projection...
What universal remote control is compatible for the mitsubishi 1080 hd series i belive mine is 55 inches? i need to align the red n blue crosses so my picture is not blurry.
ANY mitsubishi remote will work, universal remotes will not do the job.
Is color skewed and or 3 d looking?
The more you tell me the better I can help you.
SD TECH
Sep 15, 2010 | Mitsubishi WS-65315 65" Rear Projection...
How do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD-62531 Projection Television
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi hd 1080 tv humming and blurred words/ bight colors
check the capasitor near the plyback value 250 volts and also the B+ capasitor
Oct 01, 2008 | Mitsubishi WS-55807 TV
No sound in hd 1080 mode.
check to make sure that you have all the cables plugged in for that model you need a total of 5 cables for the HD input. 3 component(red,green,blue) and 2 audio(red,white)
Mar 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
1080 VS 480
Trash can it and buy a new T.V.
Jan 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi ws 55819
caps:
replace DM
Nov 10, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Display
OPTION MENU "MENU 1270" SERVICE MENU "MENU 1257" CONVERGENCE MENU "MENU 1259, 4 FINE, 5 COARSE, 6 MISC
Sep 15, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
