Question about KitchenAid KCMS145J Microwave Oven
Demo on the demo light is on
My oven AZKM755 is locked in demo mode, how do I get it off demo pls.
To turn off Demo Mode:
1. Press SETTINGS 12 times. "Demo Mode" and "ON. Press (1) to OFF" will appear in the display text area.
2. Press the "1" keypad to change the Demonstration Mode setting to Off.
3. "OFF Selected" will scroll in the text area. Demo Mode has been turned Off.
If unable to access the DEMO setting, contact Whirlpool at: https://www.whirlpool.com/services/contact-us.html
Dec 23, 2017 | In Microwave Ovens
My Panasonic genius 1250w shows DEMO on screen and does not respond to settings
"DEMO MODE" is a tool intended for in-store demonstration of the microwave oven to the consumer.
While in Demo Mode, if you push "START", the microwave will not fully operate as designed. To Exit Demo Mode, press the "Timer/Clock" button four times. If it does not work, see to your operating manual.
Nov 05, 2017 | Panasonic Microwave Ovens
I cannot stop the DEMO
Demo Mode The Demo Mode is ideal for learning how to use the microwave oven. When set, functions can be entered without actually turning on the magnetron. The microwave oven light will come on, the fan will run, the countdown will run very quickly in the display, and the turntable will rotate. To Turn On/Off: The microwave oven and Timer must be off. Touch and hold TIMER SET/OFF for 5 seconds until 1 tone sounds. Repeat to turn off.
Jan 21, 2012 | Whirlpool Microwave Ovens
My mh2175xsb microwave quit working a few days ago, that is it pretends to be working. All functions appear normal, timers, lights, fans, and even cycles when on percentage heat, but it heats nothing. The...
Hello Keith Sprague,
Spelling is close and your guess is quite excellent...
Before you ENGAGE in a wholesale repair effort...
You should check your machine is not in DEMO mode...
Demo Mode
Activate to practice using the control without actually turning on
the magnetron. Touch and hold number pad "3" for 3 seconds. The
"DEMO" icon will appear in the display. Repeat to exit Demo Mode
From page 3 (of your operators manual)
Whirlpool MH2175XSB User Instructions Electrical Requirements
Hope this helps
Carnac the Magnificent
Jul 02, 2017 | Whirlpool MH2175XS Microwave Oven
Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
We had a power blackout now my panasonic genius microwave is stuck on demo mode. How do I get it off demo mode?Is it fried or fixable?
DEMO MODE ON/OFF
Demo mode is designed for retail store display. In this mode, the oven can be demonstrated with no power in the oven.
On the "Timer/Clock: button:
4 taps ON The oven is in Demo mode.
4 more taps OFF The oven is not in Demo mode.
Mar 07, 2009 | Microwave Ovens
It says demo mode and there is no heat, everything else works
Have you checked your manual to see how to get out of demo mode? Since it is still in demo mode, you won't be able to use it for anything else. If you don't have the manual, go to GE's website and download the manual there. Also, you can check their site for Support and look for troubleshooting.
Feb 03, 2009 | GE XL1800 1100 Watts Microwave Oven
Micro wave cuts out after 20ish seconds
Try this...
Press: Function 0 2 to turn off demo mode. For future reference, Function 0 1 should turn demo mode back on.
Feb 01, 2009 | Panasonic Microwave Ovens
How do I take it off demo
timer button 4 time on demo mode
time button 4 taps more off demo mode
see page 11 of your manual
please rate me for this
Jun 23, 2008 | Panasonic NN-SD997S Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
19 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
