1998 Volvo V70 Logo
Posted on May 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Key stuck the ignition!
I have 1998 volvo v70xc awd and the key is stuck to the ignition and wont come off my steering wheel does not lok and for the key to come off it must b locked???any suggestions anyone??
  • chirp420 May 30, 2009
    ill try that!thanx!
Anonymous
Level 2:
New Friend:
  • Expert 109 Answers
  • Posted on Jun 02, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
109
Questions
Helped
62636
Points
206
Take off two-halfs of steering wheel (torx screws) put key on acc and there is a small hole in the column where the tumbler is stick a small paper clip or watch screw driver inside and the tumbler should come out this seems to be a problem after the 850 series beacause of the chip inside of the key
Anonymous
Level 3:
President:
  • Master 1,486 Answers
  • Posted on May 29, 2009
Anonymous
Master
Level 3:
President:
Answers
1486
Questions
0
Helped
633543
Points
4662
With the key stuck in you can remove the barrel by taking off steering wheel surround and puting a small nail or something like that in the hole located at the outside of the barrel.
I cannot get the key to completely turn off in the ignition of my 2002 V70XC Volvo. How can I fix this?
Is the vehicle in park ? Your vehicle like all vehicles have safety systems that won't allow the vehicle key to be turn off and locked if the vehicle is in gear and running . How ever this systems can malfunction . There is a lock out soleniod in the column or the console if floor shifter . The first place to start would be to have it checked for DTC's - diagnostic trouble codes . These codes can cut diagnostic time down a bunch . Or there could be a problem the ignition lock cylinder ! If no codes are present taking the steering wheel off to get out the lock cylinder and replacing it . You may be better of taking it to a repair shop .
How do i get my 98 volvo s7o to shift up past 2nd and fix the speedometer
Volvo Forum • New Transmission Shifting Issue - Matthews Volvo Site
www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=35574
Jan 11, 2011 - 14 posts I just completed replacement of the transmission in my son's 1998 V70xc. Problem: car runs and drives in reverse and 1st gear, but will not shift up to 2nd, etc. ... Does the upshift arrow light up if you move gear lever down in lower gears? ... use the original trans case and final drive since FWD gearboxes do ... Volvo Forum • 1998 V70 XC AWD Transmission Problems
Jul 15, 2010
Volvo Forum • 1998 V70- Should I change Transmission ...
Jun 1, 2010
More results from www.matthewsvolvosite.com
2005 Volvo S40 with key stuck in ignition. It turns off but key doesn't come, out of the steering wheel. Please advise needed, if lock change is required estimated cost of part and labour please.
Some ignition system locks will not release the key unless you push in towards the column while turning further off. It is a safety device to stop in advertent removal of the key while moving. Try that first.
2answers
I am having problems removing the key ignition in my Volvo V70xc
on my car when that happens i pop out the button on the gear shifter.
1helpful
Key is stuck in the ignition of my 1998 saturn sl.
Turn your steering wheel left or right side. If it moves, then good for you. But if doesn't, it probably means that locking system in the steering wheel is damaged. For this, you can just turn the steering wheel opposite to the direction of the car wheels. Most of the time, cars are turned off with the wheels turned on the opposite directions, which makes the key get stuck in the ignition due to pressure in the steering wheel. When the pressure is released from the steering column, a click can be heard and key is released.
If no luck, there might be a problem with shifter mechanism, which means that you have a trip to the repair shop in store for you. Get this problem addressed immediately, as it could mean that your shift interlock is out of order, which can increase the chances of deploying the air bag up in your face, causing a serious injury.
Steering column wont turn ignition is stuck
Rock Steering Wheel Back and Fourth While Turning KEY.
Or If the Wheels are Turned HARD in one direction you mest Turn Steer Wheel in THAT Direction While Turning KEY
1helpful
Locked steering wheel.
If your key won't turn, you can move the steering wheel back and forth until it does or try to hold the steering wheel to the left or right while turning the key. This happened with my car when I parked with my wheels turned in. Now I make sure the steering wheel and my wheels are straight when I park.
1helpful
3answers
Key won't come out of ingnition...
I had the same problem and found that if I made sure the button on the shift lever is out all the way the key would come out. Mine was sticking and had to be pulled out, the spring had become weak on the shift knob.
Key wont turn in the ignition button stuck in
Maybe you lock the stirring wheel. Insert the key try to turn it and at the same timeand try to stir (gently) clockwise or counteclockwise to unlock the wheel
Good Luck
1helpful
The ignition key on my 1998 volvo S70 will not come out
Try a little wd 40.My T5 wouldn't let the key go when engaging PARK.A few squirts of wd 40 down the shift mechs solved the problem
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
