Canon EOS Rebel XS 35mm SLR Camera Logo
A
Anonymous Posted on Jan 17, 2014
Format sd camera card - Canon EOS Rebel XS 35mm SLR Camera
Ric Donato
Level 2:
Novelist:
  • Canon Expert 232 Answers
  • Posted on Feb 02, 2015
Ric Donato
Canon Expert
Level 2:
Novelist:
Answers
232
Questions
Helped
87701
Points
291
Sorry not at all understanding your comment, does not appear to be a question. Here is my best guess for an answer, Always format in camera.
2answers
Samsung SL202 card error I bought an SD card with adapter and camera says "card error".
Question edited for clarity.
This is always because people buy modern SD Cards that are far too bit for older cameras. The maximum size for an SD Card is 2GB. Also you must format the card inside the camera.
https://www.manualslib.com/manual/145868/Samsung-Sl202.html?page=86&term=SD+card&selected=1#manual
How i can format my sd card for vtech camera
1. The camera will format by itself.
2. or Use any already formatted SD card.
3. or in most camera setup mode, there will be an option to format the SD Card.
2answers
HP Photosmart M425 card has wrong format press ok to format card unable to format
You could try formatting it in My Computer on PC by right clicking on its icon to bring down the option, then format again in the camera to ensure compatibility
2helpful
The sd card is not working and saying card error
Go in the camera options and format the card. If your camera does not have this option or it can't complete the format it means that :
Your card might not be formatted with the correct File System. Move your SD Card to a computer with card reader and Format with FAT32 File System the move it to camera. If the camera gives the same error, format the SD card with the NTFS file system the try again in your camera. If the SD card still don't work try FAT Fyle System.
4helpful
2answers
How to format or unformat memory card on IXUSi camera I need to know how to format and unformat the memory card I can't see the pcitures as it is showing no image on the screeen Regards C Robertson
to format a sd memory card, you can insert the card to computer or camera, and select the format. To unformat a sd memory card, a data recovery software can help you.
Are you in a dilemma as to whether to format your SD card or not? If you don't format the SD memory card, you cannot use your SD card any more, and you cannot transfer files from SD card to other devices. If you format the SD memory card, you will loss all the files like photos and videos on your SD card. Follow the link you can get the answer.
2helpful
2answers
When I turn on my Jazz DV 152/ T20 it displays "Read card..." and then nothing happens...I have a 4GB SDHC card by SanDisk...both camera and card are new....is this a faulty camera or am I doing something...
Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.
SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
2helpful
5answers
Sd card formatting
Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Top Canon Photography Experts
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Canon Photography Expert? Answer questions, earn points and help others
