Toshiba TZ50V51 50" Rear Projection Television Logo
Question about Toshiba TZ50V51 50" Rear Projection Television
Blinking red light on toshiba projction tv
Red light is blinking continuously. The TV has no picture or sound. The screen blank
5 Related Answers
Anonymous
SOURCE: TV on/off light keeps blinking red light/no sound or picture on screen
Here's a solution that I received from an TV expert in another website: "This sounds like a power supply problem. i have seen it several time on your model. i would not keep trying to turn it on it might damage something else in the tv. the reason it is shutting off is because the power supply is putting out too much voltage. a repair cost will range around 300-400. this is a great model and well worth a repair. here is a web site that might help you in finding a repairman.
http://www.nesda.com/locator/state_search.php." <-- $300-$400 is too much! But throwing away a 300lbs TV will cost a lot of $$$ for the towing and dumping too. I haven't decide what to do yet.
Posted on Dec 19, 2007
Anonymous
  • 1067 Answers
SOURCE: my toshiba wont turn on but red light come on an green light flashing no picture or sounds
yes ill got remote link for u here give me one sec
Posted on Jan 29, 2008
Anonymous
SOURCE: We have sound, but no picture
If you replace the lamp and still have no video, the problem could be the ballast. Replacement cost is similar to that of replacing the lamp.
Posted on Feb 05, 2008
Anonymous
SOURCE: toshiba hometheater 50" rearprojection
http://www.casiasfamily.com/repairlog/tp50h15.html
see the link.
the problem are the convergence amps. Its a common problem for this model. Google the model # and you'll see several postings about the blinking light.
Posted on Mar 11, 2008
Anonymous
SOURCE: toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Posted on Nov 24, 2008
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
1helpful
Have an older Toshiba theaterview TV, when turn on, we have no picture, no sound, just black screen and blinking red light that just continuously blinks.
Theaterview suggests a rear projection--in that case it most likely is in the convergence circuit--unsolder chips (convergence) and see if set turns on.
Some of their regular TV sets (picture tube) if the light is just blinking means the same thing=shutdown because of a short/problem but a model number would tell me which you have.
2answers
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
1helpful
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
2helpful
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
28helpful
5answers
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
3answers
could be the relay transistor or diode close to the relay in the power supply
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
