I activate wifi and put in the key number. The netbook keeps trying to connect, but can't. Microsoft tries to find a solution but can't. I am using the home fusion broadband on verizon. It is plugged into my desk pc, and works, and my Acer laptop can also connect. I also tried using Ralink and Linksys. Still won't connect.
If other computers are connecting to the network directly via Ethernet with no issue it sounds to me that the wireless network adapter on your netbook may be faulty or perhaps it's bieng put in incorrectly. I would try going to a free wifi Hotspot location such as McDonald's and see if it connects if it doesn't you can purchase a network USB that's plug and play online or walmart
SOURCE: hi just got a msi
press and hold the Fn key then tap the F11 key and it should show the wireless icon in the bottom left corner
SOURCE: i purchased a msi wind
Can you connect to your virgin broadband wireless through any other devices, like another laptop?
Run ipconfig /all from a command prompt & post the output....
netbook router ethernet or wireless
2 - Wireless netbook connection using your home ISP
Another way to get online with netbooks if you're at home is to connect wirelessly to your home router.
It's a very easy process - just turn the netbook on and it will seek out your router. You get a fast connection, good security (if you tell your router to use WPA encryption) and it will usually work anywhere in your house or garden. Several netbooks, laptops or other computers can use your internet connection this way from the same router, so your family and friends can use their netbooks at the same time.
3 - Wifi netbook connection out and about
A really cheap way to get online when you're out and about is Wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
Some are free and can be used by any computers that are nearby. Others are owned by telecomms operators like BT Openzone or mycloud and you need to pay to use them. Monthly subscriptions or pay as you go are available. So are these free and cheap choices ideal for using with cheap netboks?
For anything other than general browsing on netbooks, beware of wifi. The free ones have no security at all, and the others have password protection, but the data you send and receive is not encrypted. This means anyone in the vicinity could snoop and listen in on what you were doing. I don't bother with wifi for this reason.
If you have a wireless router you must know the password you made when you set the router up.
Try also to look in your controlpanel network and shareringcenter.
Hope this was helpfull.
Try these common fixes first.
Restart your router. This fix works so often that it's always worth trying first. ...
Switch Wi-Fi bands (2.4 GHz and 5 GHz) ...
Test your Wi-Fi on different devices. ...
Try a different Ethernet cable. ...
Improve the position of your device and/or router.
