This is usually caused by poor contact between the tape and heads or the tape fluctuating as it goes through. First try a cleaning tape and see if that improves matters.Then get a friend to show you how to clean the tape path with alcohol and q tips.I assume there is no picture disturbance? There could also be other reasons like the auto level not working properly but start with the basics. I hope I have been of help but please do not hesitate to ask if you have any further questions. I appreciate your vote if you appreciate my reply.
This may be caused by a bus level communication problem, try a restart.
Power down the computer, power down the library, power up the library, wait for the library to finish initialization and verify from the control panel it is in an online/ready state, power up the computer.
Hi, My Sony DCR-HC32 handycam's tape mechanism is giving me some problem. It ejects and the tape deck opens up properly but after putting a tape and closing it, the tape deck does not go in. I tried with or without tape but it doesn't go in. It is still open. Can you please suggest how it could be fixed? Thanks, Pramod
there are small rubber belts that drive the tape spindle that makes the tape play! Over time these stretch and become loose and make the tapes play slowly and even shut down (replace belts and it should be fine) these belts are located in back of tape spindel and are about two inches long!
Please rate my answer and keep this site FREE!
I'm having a similar problem. The camera is a Sony
DCR-TRV280.
When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down.
In other words the mechanism works fine without the tape but with the tape it doesn't.
I hope the explanation is clear enough.
Thanks
