Question about Panasonic DMR-E80H DVD Recorder
Dmr-eh80veg is dead
Absolutely nothing happens when pressing On/off button. Fuse on power pcb OK. Transistors in Power PCB gets a little bit warm and I can measure +12 v near the output connector.
5 Suggested Answers
ABRsvcs
  • 4234 Answers
SOURCE: panasonic dmr es30v
Without seeing the actual unit, I would guess that the power supply has failed. These unit have what are called "switch mode" supplies that rely on circuits that oscillate. If a capacitor goes bad, the unit won't oscillate properly, thus no power. These are difficult to track, but are not usually expensive to repair. I would suggest a trip to a service center for a detailed repair estimate. Report the results here.
Dan
Posted on Feb 01, 2009
Anonymous
  • 25 Answers
SOURCE: got power plays for 5 mins then dies loss of
Unit may need service contact panasonic or visit website for servicer.
Posted on Sep 28, 2009
Testimonial: "Thank you I thought I may have to do this. Regards John."
Anonymous
SOURCE: Panasonic DMR-ES46V shows F60 Error
I have same problem with es40v - f60 error with no response to troubleshooting protocol. This machine also was used very little & also has a history of turning itself on. Panasonic used to make high quality products. A shame that their products are no longer trustworthy. I can understand that machines break - i'm very frustrated to learn replacement parts are not available. Guess i need to re- think brand loyalty.
Posted on Feb 12, 2010
Anonymous
SOURCE: X HOLD on player screen if button press. Panasonic DMR-ES10
My Panasonic is doing the same (displaying HOLD). Did you find out what the problem was?
Posted on Jun 13, 2010
caroldon
  • 17130 Answers
SOURCE: Hello, i have a panasonic
When you are powering the set the power supply and the control boarrd is working alright but when the set is triggered to switch on the microprocessor is not powering up but is shutting down the system
So possible errors can be
1. failure of the control drive of the loading
2. failure off the HDD drive which is not starting up.
3.failure of the main board.
I sugggest that youkeep the set powered on for abotu 12 hours- overnight - to see if the warm up can rectify the fault that can be a passive section powering up slowly.
Posted on Sep 23, 2010
How do i solve an error e000-0000 canon ir 2002n please
Description
The main thermistor reading does not reach 40C 14 sec after the fixing heater goes ON (fixing low temperature error)
Remedy
1) Wiring Is the connection of the connector (CN8) on the power supply PCB and the connector (J103) on the DC controller PCB and the wiring to the fixing assembly normal? NO : Correct the connection and wiring. 2) Fixing assembly Try replacing the fixing assembly. Is the fault corrected? YES : End. 3) Power supply PCB, DC controller PCB Try repacking the power supply PCB. Is the fault corrected? YES : End. NO : Replace the DC controller PCB. 4) Error With the power switch ON, clear E000 through E004; then, turn off and then on the power switch.
Aug 05, 2015 | Canon Office Equipment & Supplies
Will not power on
Is this monitor supplied from AC outlet straight or through AC-adapter? If through adapter check the voltage on DC connector. If straight, then you need to open monitor and check fuse, located on the power supply PCB, carefully, don't get electrocuted, because in some models the large capacitor in the switching power supply may hold the charge for long time.
If fuse is ok, take a look over all electrolytic capacitors on the power supply board, are there any of them blown or even just little bit rounded on top? If yes, replace them with proper ones. Also take a look at solder side of PCB and carefully check if there are some cracked junctions, especially at power diodes, heat-sinked transistors, power resistors and pulse transformer - as far as these parts are heating more than others. Described steps can troubleshoot half of all problems in LCD monitors.
Aug 17, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Marantz CDR631 is dead
open it up and take the mechanism out, then you should see a servo PCB screwed to the underside of the mechanism.
unscrew this and where the connecting wires plug in from the main PCB, you should see 2 or 3 fuses which look a bit like capacitors and should be red in colour marked MPXXX eg. MP100?
replace these if you can find spares, if not bridge them with a bit of thin wire soldered in place and then it should switch on once reassembled.
the clicking sound you mention will be the main power supply capacitors running and this is normal.
Dec 31, 2008 | Marantz CDR631 CD Recorder
Cameras dead
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon if it is out or warranty (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
If we can help with your repair then please let us know.
Hope this helps,
Thomas
Darntoothysam com
Nov 10, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Dropped DS Lite - rattling
L2 inductor comes out sometimes when dropped and the DS keeps in fixed amber light when charger is plugged in. But you found it fast so good luck. Its pretty sure your DS will work again after soldering the L2 again in its place near the power switch. Just get the battery and charger out before doing anything to avoid a blown fuse also.
Sep 05, 2008 | Nintendo DS Lite Console
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
Panasonic DMR-E80H DVD Recorder Logo
62 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
