Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trinitron 32 tv
I turn on the unit, see a purple screen and within 15 seconds it turns itself off.  I can kinda see a tv show through the purple curtain but changing the channel (within those 15 seocnds) seems to do nothing and i hvae tried to change the video ouput to video 2 or something and it looks like it may be doing something but it is all behind the purple haze. I don't want to pay to much to fix it and was wondering if it was worth it and what was wrong with it. thanks
Posted by Rosalyn5 on
Vista Electronics
    Genius:
  • 1,694 Answers
1) Could be bad CRT ( picture tube )===no green==purple.
 2) Might be lack of green drive to CRT==bad transistor.
 Recommend analysis by technician--usually worth it if CRT ok.
Posted on Oct 22, 2007
I thought I asked this already but it does not show up. I have a 15" lcd tv that will only stay lighted for a few seconds on each channel then goes dark. I can kinda see a image on the dark screen. I...
the backlight is either going out or the capacitor for the backlight is bad to where its not storing enough power to run the backlight the start capacitor must be good but the run capacitor might be bad usually the backlight itself goes bad but not if it turns on for a few seconds it would have to be the capacitor.
Oct 04, 2013 | Philips Magnavox 15MF400T 15 in. LCD...
My sharp 15" LC-AV4U TV turns off within 5 seconds of when it is turned on any help
Jan 26, 2010 | Sharp LC-15AV4U 15 in. LCD Television
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Turns off by itself
ther is technical error
Jul 11, 2009 | JVC LT-32P679 32 in. LCD TV
Screen changes colors only
Hold the Vol+ Vol- buttons down and turn on the power switch in the back of the unit.
The screen should turn blue and some square in the middle of it.
The noisy square is actually the bios being reset.
Once the unit turns itself off, you can turn it back as usual.
Note: Some of these units require a 3 button reset.
In that case hold Vol+ Vol- and Menu at the same time while you turn the power switch on in the back of the set.
I hope it was helpful.
Jul 07, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
RCA 27F520 Shutdown after a few seconds
you have lost the vertical ic and maybe resistor or capacitor.
but you also maybe loosing the horizontal ic
you will also have to check the voltages on the flyback transformer that go to those circuit's to see if they drop or are correct
Dec 22, 2008 | RCA TruFlat 27F520T 27" TV
Have a small lcd flat screen tv- 4 mos old
you have to repair its power supply, there are a couple of capacitors you have are almost short that's why the TV is turning of so to be in safe mode from power failure. Please contact a good technician in you place for a service. Patrick
May 21, 2007 | Symphonic ST419E TV
Something wrong
A jammed or defective VCR can cause this symptom if the TV is turning itself off within about 15 seconds of turn on. Otherwise, it could be anything from a bad capacitor in the power supply to a shorted component in the High Voltage/deflection circuits. In other words, time to replace it.
Dec 18, 2006 | Sharp 13VT-R100 13 in. TV/VCR Combo
Purple tint on screen
Color splases can show up when the sets are move from one location to another or when they have been dropped while moving it,another reason is when a speaker is placed to close to the tv.The tv has an internal demagnetizer witch gets activated when you turn the tv on,I suggest to unplug the unit for about 15 minutes and then plug the unit and turn it on,If the unit was dropped this problem might not be repairable.I hope the information helps .
Oct 02, 2006 | Symphonic SC519DD 19 in. TV/DVD Combo
Vertical Green/Purple Lines on lower half of screen
I would contact RCA if the repair center dosent know how to troubleshoot this set. But I bet its an eeprom or ground issue. Contact RCA here at 580-634-0151 or At https://www.rca.com/secure/service/contactrca/1,,,00.html Good Luck
Jun 15, 2006 | RCA Scenium HD65W20 65" Rear Projection...
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
184 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
