Question about Staples SPL-P500 Printing Calculator
How do I set the constant operation - Staples SPL-P500 Printing Calculator
How to fix vats on 98 sonoma
What's wrong with it , have you had it checked for DTC'S - diagnostice trouble codes .
The design of the passlock™ system is to prevent the vehicle operation if the proper ignition key is not used in order to start the vehicle. The mechanical key, in normal operation, will turn the passlock™ lock cylinder. The passlock™ sensor will relay the passlock™ data to the body control module (BCM). The BCM will determine the validity of the passlock™ data. The BCM will send a code password to the vehicle/powertrain control module (VCM/PCM). When the VCM/PCM receives the correct code the VCM/PCM allows the fuel injectors to operate normally. The passlock™ system requires the VCM/PCM and the BCM to communicate the various functions in order to operate. These functions transmit over the class 2 serial data line CKT 1807. For an explanation of the class 2 serial data operation refer to Data Link Connector Circuit Description in Wiring Systems.
Telltale Indication
Condition
ON constant for 3 seconds, then OFF
The bulb check occurs upon power-up (Ignition 1 and crank).
ON constant for 3 seconds, OFF momentarily, ON constant/ignition OFF
DTC (current) is set with the ignition ON (see DTC B2947, B2948, B2957 and B2958).
The TBC fuse is open or an open in CKT 1140
ON constant for 3 seconds, FLASH for 10 minutes, then OFF
Occurs when a Passlock™ sensor has been replaced and the ignition switch has been turned from the OFF position to the CRANK position. This sequence occurs 3 times.
FLASH with the ignition ON
The Passlock system is in a tamper mode (see DTC B2960 and B3033).
ON constant for 3 seconds, OFF momentarily, then ON constant for 10 minutes, then OFF
Occurs when a new BCM or a new PCM/VCM has been installed, and the ignition switch has been turned from the OFF position to the CRANK position. This sequence occurs 3 times.
ON constant for 3 seconds, OFF for 2 seconds, then ON constant
The IPC is unable to communicate with the BCM.
DTC B2947 Security System Sensor Power CKT Low
DTC B2948 Security System Sensor Power CKT High
DTC B2957 Security System Sensor Data Circuit Low
DTC B2958 Security System Sensor Data Circuit High
DTC B2960 Sec Sys Sensor Data Incorrect but Valid
DTC B3031 Security System Controller in Learn Mode
DTC B3033 Security System Indicates Tamper .
Your best bet , take your vehicle to a qualified repair shop .
Feb 17, 2017 | 1998 GMC Sonoma
Have all my setting correct for 5 pm start time, 9 pm off time, but it is on constantly. Using on indoor Christmas lights set program 1 & 2 the same.
  • The timer could be defective
  • You may not have set the current time
  • After programming, you may have to select RUN to start timed operation
  • You may have selected manual operation even though you set times
Dec 17, 2015 | Hardware & Accessories
Trying to set the IPT Path for Anona Labs and getting an error
I think this Anona Labs is gone. There isn't even a web site for them. Have you tried just setting to the default path?
Jan 04, 2014 | Computers & Internet
This is so easy but I've forgotten. I have an old manual Casio caluculator. I just want to divide a series of numbers by 4. I can't seem to figure out how to do it. Any ideas? Thanks, Julia
If your calculator has the capabilities to do constant calculations here is how you perform calculations with a constant.
  1. Enter the constant (4)
  2. Press the operation key (/) once.
  3. Press the operation key (/) a second time.
  4. Your calculator may show a k in its display (LCD)
  5. To divide a number by 4, enter the number and press =
  6. To divide another number by the constant (4) , Enter the number and press =
  7. Keep entering the dividends and pressing =
I hope it works for you.
Oct 01, 2010 | Office Equipment & Supplies
Tv will not turn on. timer light constantly blinks
If you can get into the main menu go to load factory default and reboot, This will reload factory settings and this operation will erase all unwanted settings and load back to factory default. so you can load your own settings and take back control of your tv.
Feb 23, 2010 | Toshiba 42HL196 42 in. LCD HDTV
Hello, i find it impossible to maintain a constant speed (about 30mph) without the bike juddering , im having to open throttle - close throttle constantly to keep at 30. it has been back for repair and...
Bikes like yours with high horsepower output, a high revving engine, and relatively light weight are very sensitive when operated at low speed - and at low power settings. I have found that usually, after getting well acquainted with a particular bike, things become much easier have a fine control over. In the meantime, try running in higher - or lower gear, at that speed. Sometimes that can make constant throttle movements less necessary.
Feb 21, 2010 | 1998 Yamaha YZF 600 R thunder cat
My Diamond vc500 constantly takes pics HELP!
Check the configuration settings - you may have the automatic frame grab feature activated.
Feb 08, 2010 | Diamond Multimedia ( VC500) Video Capture
Staples SPL-P500 Printing Calculator Logo
54 people viewed this question
Top Staples Office Equipment & Supplies Experts
John mullen
gbob59
Marvin
Marvin
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
