Great camera, but after 3 years now won't write to any standard sd card, just to internal memory, do I need to buy a new camera?
Not sure you tried all the things I should do.
Be sure the cards are formatted, and try to format them in the camera.
But before you put in any card, check with a bright light close to the memory card slot, if all the contacts are clean and free, Just a little bit of dust or paper on one contact, could spoil all the fun. The contacts should be clem and shiny. All straight and to one side, Not one can be a little bent. If someone ever pressed a memory card in the camera the wrong way around, a lot of damage should be seen down there with some contacts bent or broken.
And be sure you did not switch all the cards to the lock position.
SOURCE: Fuji FinePix S700 Problem
Try to put it on super macro and see if this will reset the zoom function.
Also try to switch between the settings that allow the digital zoom, as compaired to those settings that only allow optical zoom.
If these do not work, you may have a lens that has been dropped, or is stuck, and may need to be serviced. I have the S700, and have never seen this error before> good luck.
SOURCE: screen reading memory card not initialized
I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
help me i also have the same problem please email me how you fixed the problem? [email protected]
mahalo's
SOURCE: camera or memory card "CARD FULL" error
Check to see if in your settings you are putting the pictures onto the memory card or the cameras internal memory. If there is no internal memory, then I guess that's no help. Also check to see if the card is write protected (a little switch on the side of it).
Have you formatted the memory card recently?
