Sharp ll-m17w1u 17" Flat Panel LCD Monitor Logo
A
Anonymous Posted on Jan 17, 2014
"out of timing" message on sharp LCD monitor at turn on
1helpful
I replaced power board for a Samsung TV model #UN40F6300AF installed today. TV still turns off. If i turn the the TV on 5 or six times the tv will work fine. Any other suggestions on what to replace
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that
Normal behavior. Most of the lcd monitors ( not all) show this message. You can safely turn off the monitor once you shutdown your computer.
I have sharp flat screen tv the tv want turn on and the opc light blinks one and the power blinks one time together what to do
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
3answers
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
1helpful
AOC 26" LCD 619Fh Problem
Go to "Picture Boost" option in the "OSD window". Then turn on the "Bright Frame" option and after that make the "Frame Size" to 100. That's it now you can get a perfect sharp image...it worked for me.
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Sharp Aquos 15 LCD TV
Maybe. Unplug the unit and disassembly it. Look for damaged parts or cracked circuit boards. You may also find the buttons you push to turn it on and activate the menu ect. may be damaged. In most cases the board can be repaired but because that would be time consuming and the repair man charges 60 bucks an hour it is usully not cost effective. You might get lucky and find a wire that fell off in the fall. Good luck.
2answers
LCD monitor very dark.
The fault may lie with the ccfl inverter which basically provides a high voltage to drive backlighting for the lcd display. Not sure where you can get this part other than Sharp, but look round on the internet on this subject. I successfully repaired a similar problem with a portable dvd player using a ccfl inverter normally used to modify pc base units with neon-type tubes. Cheaply available at Maplin electronics,but may be a bit large to fit inside the monitor? Could be fitted outside as the wiring is quite long enough?
Top Sharp Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
john h
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
