Question about XO Vision XOD1735 Car DVD Player
After I connect all the wire, it doesn't have any sounds coming out
I can't find the amp wire to connect with my car.
Posted by Mu Yuan on
  • Mu Yuan Jan 18, 2014
    I have metro and there is a wire need to connect to amp, but I can't find it, so which wire do I need to connect with
Does not switch on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode
Jan 18, 2013 | Yamaha RX-595 Receiver
Yamaha RA-V1200 wont turn on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .if it stays on whit no wires attached than u have short connection at speaker wires . if doesn`t come on then try to fasten screws at back of the unit , may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happened to me on RX-V592
Jan 16, 2013 | Yamaha RX-V1200 Receiver
Yamaha RX-V595 receiver won't stay on
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
Yamaha amplifier not turning on
Dec 23, 2012 | Yamaha Audio Players & Recorders
My yamaha_rx-v457 is automatically switching off when i turn on
Dec 21, 2012 | Yamaha RX-V457 Receiver
My amp will not turn on
Dec 19, 2012 | Yamaha HTR5950
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
I have no sound coming from my sub or my back speakers. all the fuses are fine and all connections are fine as well and the blue light on my amp is on. and the it seem the power light and protection light...
With the radio OFF, take a jumper wire and connect from the 12V input to the remote input of the amp to see if it powers on.(BE CAREFUL NOT TO TOUCH THE GROUND). If it does, your remote from the radio is either cut somewhere, or not working at all. If it doesn't turn on then turn on the radio and do the same thing with the jumper wire, if it turns on, then your 12V power from battery is not working, maybe a blown fuse by the battery?
Jul 28, 2011 | Car Audio & Video
Heater doesn,t work. Controls on dash sometimes light up & sometimes doesn,t. All of my fuses are good. It seems to act up mostly in the morning. Sometimes if I turn my head lights on my gauges quit...
Morning Charlie,
If it were me, I would check the wires coming & going to & from engine. Maybe something is crossed. That's what it sounds like, anyways.
Oct 08, 2010 | 1996 Jeep Cherokee
Amp wont produce sound when car is on only when car is off it works
Ok do this little experiment when you turn on the car again disconnect the amp turn on wire from the amp. then get a small wire then strip back both ends with a wire stripper only exposing enough for the copper wire to show. then touch one end to the 12volt on the amp and touch the other end to the amp turn on terminal. The amp should come on and the sound should come on. Your problem then is your amp turn on connection is wrong and may be connected to the power antenna wire which may not be able to handle the load and shuts off so I suggest connecting it to the ignition wire so whenever the radio is on that wire will send 12 volts to the amp to turn it on. Sometimes On the back of the radio harness there are two blue wires. One is Blue and the other is blue white. Always connect it to the Blue white cause thats the amp turn on wire. The solid blue wire is the power antennna wire. Also possible the blue/white wire is sending a weak 12volt signal so just connect it to the red wire which is the ignition wire. Dont connect it to the yellow wire because thats constant 12 volt. If you connect it there the amp will always be on and drain your car battery and you might hear big loud buzz sound when you turn off your car.
Apr 07, 2010 | American Pro VS1405 Car Audio Amplifier
XO Vision XOD1735 Car DVD Player Logo
Top XO Vision Car Audio & Video Experts
ADMIN Canada
ADMIN Canada
ray gallant
Relax
Relax
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
