Question about Sony RDP-X200IP Premium Speaker Dock System For iPad, iPod, And iPhone - Black
Opening up the unit
Hi, i need to know how to open up the casing of my rdp x200ip
Posted by dan silcock on
paul randall
You will be removing a total of 14 screws. Four are visible externally and are located on the underside of the unit. Remove them. Now, as you look at the back of the unit there will be a trim piece around the edge, the shape of an elongated upside down "U".It is held in with adhesive and use a plastic tool to gently pry off that trim . Removing that trim exposes 8 screws , three each on the sides and two on one of the long sides. remove them. Now hold the docking pin assembly ( where you plug in your device) and gently pull up a little bit to reveal two more screws. Remove those and you will be able to separate ( but not far apart) the front from the back. The Back part is hollow for the most part and the speakers and rest of electronics is on the front part. Hope this helps.
Posted on Nov 10, 2021
I just received my Ematic EPD707BL. It opens with the word ematic. Nothing to click on for DVD or menu. When I put in a CD and DVD it says no disc
Check the connector from board to laser unit which is open for which it shows no disc. The lens is under the CD or DVD case.
1helpful
How do you open the case on a dragon touch x10 octa core tablet
You don't. Most are self contained. They are manufactured by inserting the electronics into the shell and then gluing the screen to the case. If you need to access the innards, you need to physically cut the screen away from the case shell. This almost always results in screen breakage. This is done to make them shock resistant and since the most common repair is screen replacement, they'd have to break it to replace it anyway. Also, this way they know you won't go fooling around inside the device.
2helpful
How to open up the JBL onbeat rumble?
The power connection on my JBL Onbeat Rumble stopped working also. I could usually jiggle it to get it going but this wasn't a reliable solution. I note there were a few people online that have complained about this but no solutions or disassembly guides. With nothing to lose I set about pulling the unit apart to fix it... here's hoping it will help others:
1. Under the orange base rubber there are five screws. You need to carefully peel off the rubber to get to the screws. Also under the sticker on the input/output section there are two screws to undo.
2. See photo for positioning of rear clips. You might be able to use an appropriate tool to undo them. I used brute force to open the case and the rear clips didn't break.
3. There are two more clips and two screws at the front of the unit.
I don't know how to get to the screws - possibly you need to unclip the front of the unit and grille. I just used additional brute force which undid the clips and snapped the screw mounts. The unit was then completely opened up into two halves.
4. You can now get to the input/output section. There are four screws to undo before you can lift it out. In my case I could see a cracked solder joint on the power input so I re-soldered it as best I could and confirmed the unit was now being powered up reliably.
5. To reassemble, reseat the input/output board, clip the unit back together, re-insert the 5 base screws + 2 input/output screws, then glue the rubber back on (it might be sticky enough not to need additional glue). The snapped screw mounts don't seem to matter as the remaining clips are strong. Just shake out any plastic pieces to avoid rattles.
How do I get my Proscan 7" Google Play Tablet to open where i can use it
Somewhere on your unit there should be a pinhole. On my ten inch it is just to the right of the charger outlet. Open a paper clip and gently press it into that pinhole. That is there to reset the unit in case it hangs. Don't press too hard or you may damage the contact. You should see it shut down and reset. You may lose any data or apps you have.
2helpful
Replace battery 7in proscan tablet
You have to watch that the buttons don't fall out of place when you open it. So use a strip of masking tape to hold them in place before you open the case.
To open the tablet it snaps in all around. You need to insert a small screw driver between the case edge and another small screwdriver to keep prying all the way around. You can hear it when it snaps open. You may need the point of a small sharp knife first. I have opened and closed mine to get the battery number. I will be replacing mine as well. You need to solder the new battery in.
1helpful
How to open a Toshiba AT300 to replace the USB connector
you could look at a step by step video on the internet or youtube. it helped me.
1helpful
2answers
My nexus 7 is not turning on anymore. It's been charging for days. Any ideas?
The battery connector in the Nexus 7 (2012 model) is notoriously problematic. Sometimes dropping the device can cause issues that prevent the Nexus 7 from charging altogether. A hard reset may not work. Fortunately, it is quite easy to fix.
However this will void your warranty. Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.
2helpful
3answers
How to remove battery from zeepad 7.0 tablet
Hi open a zeepad is very easy, you need apply some pressure over the case and the screen. I recently open my sons tablets. regards.
How to use keyboard/upper and lower case
Hi
Open the keyboard and touch the CAPS On and your Upper case, CAPS Off lower case word
1helpful
The DVD drive for my Averatec C3500 does not eject.
First check the bios settings, set to the default settings.
You can dowload a bootable linux CD from here:
http://www.knoppix.org/  (I recommend the v3.3)
If you can use a cd with that it is a software problem.
Sony RDP-X200IP Premium Speaker Dock System For iPad, iPod, And iPhone - Black Logo
Top Sony Tablets & eReaders Experts
Stan Ford
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Sony Tablet and eReader Expert? Answer questions, earn points and help others
