Question about Rheem Water Heaters
What to do to water heater for vacation - water will be shut off.
Posted by Elnora Jackson on
Mike Butler
  • Rheem Master
  • 6,674 Answers
Turn off hydro to heater and drain it. Be sure to refill heater first then turn hydro back on so you don't burn out element. If gas, shut it off as well, and drain and fill same as hydro/electric .
Posted on Jan 16, 2014
I have a Bradford white water heater- how do I check if it is on vacation mode?
The gas valve dial, which is in front of the heater near the bottom, will say "Vacation" mode. Just line up the pointer with the word vacation. Some models no longer use the word "Vacation", replaced with "Low or Warm". It will be the setting just before "OFF"
See Pics (inside blue box) answers your questions:
Feb 13, 2015 | Water Water Heaters
I'm going on 2 month vacation during ny upstate winter. I'm shutting off all water at the main house inlet. Rather than emptying my gas water heater, I'd like to keep in in "vacation"mode. Will that work?
Since it will not be boiling it will not lose any water, however I would be concerned about the low temperatures allowing mold or Legionnaires in rare cases to grow, I would call a local plumber for their opinion as to drain or not for your area.
I would drain it and leave it open at the drain and the T and P valve if possible.
Jan 10, 2015 | Water Water Heaters
How do I set ao smith pro max model ect 52 on vacation mode
No vacation mode in this heater. I have used this for last 5 years.
Dec 18, 2014 | AO Smith A O Smith Water Heater Hot...
I have a Richmond 40 gal water heater model# 6G40PVW-40PF manufactured 5/2010 and it wont't stay lit. I don't have the owners manual as we purchased our home in 12/2011 and it was a foreclosu
Well I you have the problem resolved by now, but I will answer anyhow. This just happened to me yesterday with the same water heater that you have. My problem was that the flame sensor was dirty and not picking up that the burner was lit, so it shuts everything down and goes into lockout mode. I had a similar problem with my furnace lighting system. It is called flame rectification. What actually happens is the flame itself allows a small current to flow through it, so the flame sensor actuall makes electrical contact with the burner. The control senses this connection and knows then, that the flame is on. If it doesn't sense this connection, it thinks the flame is out, so it must shut off the gas valve to prevent a possible explosion. Take your burner out and clean up everything in there, being careful not to break the small glass bulb inside, which is another safety device. Fine emery cloth of a wire brush will clean up the flame sensor good. Also wire brush the burner itself, since this is the other end of the rectification circuit.
Apr 01, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
Hello, thermostate will not stay lit. vacation
Hello, if your going on vacation any way, just shut the power to it off at the breaker box and deal with it later.
Jul 07, 2009 | Fasco Bradford White Hot Water Heater...
Water Heaters Logo
50 people viewed this question
Top Rheem Water Heaters Experts
Bill Johnson
jdthefixer
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
