What causes these pin holes?
SOURCE: Repair pin hole in metal fuel line for Pontiac Gram Am car
use pipe slice to cut metal pipe then put plastic pipe over both ends and then shrink plastic pipe by pouring boiling water over it hope this helps from johnmac
SOURCE: the wiring on the 8 pin harness has come apart
Red,black,orange,pink. bottom is yellow,hole,green,light blue/yellow
SOURCE: caliper pin/bolts location
Top to keep it grease sealed.You never have to take that out if your changing pads.Only when you are changing the caliper
SOURCE: carburetor is leaking through a small pin hole,
the "hole" is an atmosphere vent, what is happening is the needle that shuts off the fuel to the carb when the bowl is full is not working properly, depending on model the carb repair kit that is most used to repair plastic tubed carbs is 632760b .....also be sure to flush out tank and fuel lines before adding fresh 89 octane fuel to the fuel system....hope this helps
SOURCE: logitech x-230 9 pin problem . i need to manualy
worked on this for 3 days but i finaly got it I had to open it an follow coper lines using datasheet, the connector is RS232 the pins are
1 = LED+
2 = IN R
3 = OUT R
4 = OUT L
5 = GND
6 = ON
7 = 5V
8 = GND
9 = IN L
so you have to put a swiths between pin 6 and 7
you should also put a potentiometer GND-IN-(AUDIO SOURCE)
and a led between pin 1 and GND
and that is it!
---POXTRON---
