Need to turn-on touch pad of emachnes E620 - Computers & Internet
Posted by Patricia Seymour on
Brian Acker
    New Friend:
    Problem Solver:
  • 12 Answers
You may need a driver for the touch pad ,go into device manager and check on if you have one that is working properly ,then update it cant hurt ,let me know if it worked .
Posted on Jan 16, 2014
Touch pad sony viao vpceb3j1e not working
Hey there. Often times this is a problem caused by accidentally turning it off. Look for a button on your keyboard or near the touch pad to turn the touch pad on/off. If you're using windows 7 and possible below, you won't need drivers to get the touch pad to work normally.
Jul 26, 2011 | Computers & Internet
Is there a built-in microphone on the acer e627-5036? if so how do i turn it on.
eMachines E620-5885 does have a built-in microphone next the webcam. But there isn't a button to manually turn the mic on/off. The microphone is there whenever you need. For example on Windows Live Messenger or Google Talk. And these applications also have feature to test your microphone.
Hope I've been helpfull. If you need more information or assistance, add a comment to this post.
Apr 18, 2011 | eMachines E620-5885 Notebook
THE TOUCHPAD MOUSE JUST QUITE WORKING DOES IT NEED REPLACE AND IS IT SEPARATE FRON THE KEYBOARD
It is hard to tell if the touch-pad needs replacing from the information you gave. However, I can tell you that the touch-pad is NOT part of the keyboard.
There are several things the can cause the touch-pad not to work. 1) It may have been turned off in the BIOS. 2) It may have been turned off by the operating system software or 3) You may have installed a usb mouse which in some cases will override the touch-pad. 4) The touch-pad may have a bad connection into the motherboard or into the touch-pad circuits.
I wouldn't go replacing the pad until I had tried all the other possible areas because this requires a complete screw removal from the bottom, removing the display and keyboard. Then removal of the upper case of the laptop. I do this as a last resort.
Apr 01, 2011 | Computers & Internet
Might have been dropped, paart of the screen stays a violet color instead of changing colors with the image on the screen the image is that of dragon almost. The other thing I noted was I cannot get the...
yeah its taken a pretty good hit, the screen has a broken ink cartrige, and the touch pad for the mouse has probably come unpluged from the mother board
Sep 18, 2010 | eMachines E620-5885 Notebook
My toshiba satellite A355D touch pad is not working. my husband told me that probably my kid turned it off. if that is the case... how can i turn it on?
Sounds like your touch pad may need to be replaced.You can't really turn off the touch pad.Even if your child managed to uninstall the touch pad it would load back the drivers at next startup.Chances are the touch pad will have to be replaced.Its possible the touch pad may be disconnected from the motherboard but not very likely though.
Aug 24, 2010 | Computers & Internet
I need a battery for my emachine laptop and dont know where to get one.the model is E620
I buy a new battery for my Acer Emachines E620 but my computer is dead.. and want to sell it, if you want to buy it. please send me an email to [email protected] Thanks
Jul 07, 2010 | eMachines E620-5885 Notebook
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Dont know how to use webcam on E620
Hello barbaraberry , if your nootbook is Acer eMachine E620 You have to installe Driver for it this is the link : ftp://ftp.work.acer-euro.com/notebook/.em/E620/XP%20SP2/08_Camera.zip
Jun 11, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
29 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
