When I open my car door the radio turns on and starts cycling through the CD's. There is no key in the ignition. Just open the door and it turns on. When I shut off the car and close the door it does the same thing then shuts off.
SOURCE: 1995 Lincoln Town Car-Electrical system will not shut off
There seems to be a Problem with the electronic part of you Ignition switch. Good Luck
SOURCE: RADIO WON'T TURN OFF WHEN KEY IS TAKEN OUT OF IGNITION
The other item is could be, if not a defective door switch, is some of the new MY trucks develop broken wires from the door to A-pillar.
This should be a black w/ yellow stripe wire in the harness between the door and a pillar. Not very common, but has happened more then once.
SOURCE: Radio will not shut off once key is removed...
radios have two feeds one from the ignition and one permanent live. if this is the case then you will find they have not fitted in correct order or even in some cases not at all on the ignition as it does not realy need it. you will also find if the stereo is brand new that all the cables will be clearly marked with a tag and you will have to disconnect the cable for the connection to the car warnign system.
SOURCE: Rear door won't stay shut
Check the latch mechanism on the door. There is a piece of the latch that closes around the clasp on the door frame. sometimes this closes when the door is open and you can't shut the door. Take a screw driver and flip this latch piece open and close the door.
SOURCE: My radio plays without keys in the ignition.
The fuse for the radio will be located in your fuse box under the dash
