Question about Element Electronics ELCHW261 26 in. TV
MY MENU, VOLUME, MISC, SCREENS KEEP POPING UP UNDER NORMAL OPERATION OF TV.
IS THERE A PROBLEM WITH THE PROGRAMING OF THE TV?
Posted by rON dAVIS on
Neal H
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Take the batteries out of the remote. If the problem stops, the remote maybe needs cleaning. I don't think it's a Quark in the programming. If you're handy with a soldering iron, look for cold solder points on chips. And any other component.
Posted on Jan 18, 2014
I keep getting I reboot menu seen cannot load volume / misc on the a drive how do I fix it.can you fix it
Dear Costmer,
please follwup thi inctruction,
Formatting /data...
Formatting /cache...
Data wipe complete.
E; Cannot load volume /misc!
[email protected]
Feb 12, 2015 | Computers & Internet
The menu options keep poping up
I doubt this is a user fix. There is a problem in a mother board .
I would run to the warranty and try to replace it.
Mar 09, 2014 | Televison & Video
I have a r52wh74 rca hdtv flatscreen the tv menue keep on poping up fast on the screen and the volume goes up and down
Thats a common issue with that chassis ITC222A which is always caused by the small signal board needing replacement. You should be able to get the small signal board from www.tvrepairworld.com
Feb 27, 2013 | RCA R52WH73 Projection Television
The tv menu screen keeps popping on and off when watching TV. Sometimes the sound volume control screen will appear but you cannot control the volume. The set is only 4 months old.
It should be under warranty still but if not and menu comes up on its own I would suspect a problem with the keyboard where the buttons are---they may look and feel fine but they usually are the cause of this kind of problem----In several cases I have had to remove individual micro switches under the buttons to confirm or deny this---if for example menu is disabled by removal of that switch (not the plastic button but the switch under it) then the set can be operated with the remote-----I would see about getting it fixed/replaced even if just out of warranty.
Oct 29, 2012 | RCA 32" LED HDTV LED32B30RQ - ON Corp US,...
My LG T.V's Menu keeps popping up and wont go away, when i try to exit off it, it just pops back up, sometimes it doesnt go away the after a few minutes it does then comes back, I dont have any extra...
The tv manual control buttons board like POWER,MENU,INPUTS,CHANNELS - +,VOLUME - + could be bad and causing this problems.Take the tv aparts,unplug the connection that plug of the mamual pc board functions,the tv will work as normal only no manual buttons functions,if the Menu screen stop poping up,than u know the manual control buttons board is bad must be replace.If Menu it still poping up,than u have a bigger problems,the tv Tuner signal board is the cause and the problems.That the board,that take in the incomming broadcasting cable wire is the problems.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes boards like the manual control buttons board or the tv Tuner signal board.
Mar 23, 2011 | LG W2284F 22" 2ms LCD Monitor - Black LCD...
32 inch tv goes from normal sound during program to extreme loud
May be a defect but, if you notice the sound changes with different channels or movies or HD or Standard, look for a volume limiter control button in the menu setup under audio control. Sometimes the menu has a control that you can turn on to limit different volume levels during the shows origination.
Mar 12, 2009 | Televison & Video
Black box keeps poping up in the middle of the tv
your closed captions are turned on and in the text mode. turn them off or select cc1 to view that captions
Jan 06, 2009 | Insignia IS-LCDTV32 32 in. Television
KEEPS POPING UP GUIDE PLUS MENU
try to change all the micro switch button on the pcb board
Dec 08, 2008 | RCA F25442 25" TV
I need to program the remote from my TivoHD to operate power and volume on my Samsung LN52A850
You should be able to go to the tivo menu and push Messages and Settings, followed by Settings, and finally Remote Control. Then follow the directions on the screen. You normally would program volume and mute, power, and tv input. It will walk you through the manufacturers and give you the codes to try.
If the codes do not work, it is possible that Tivo does not have the codes for the TV yet, but I would first make sure that you have the most recent version of the Tivo operating system (force a network connection a few times).
Nov 25, 2008 | Samsung PCK5315RX TV
Screen problem
That's the text box function of the closed caption decoder. Look for buttons with "CAP", "TEXT","CCD", or "CLOSED CAPTION". Look in menu for same.
Nov 11, 2008 | Broksonic CTSGT9369CTT 19 in. TV/VCR Combo
Element Electronics ELCHW261 26 in. TV Logo
95 people viewed this question
Top Element Electronics Televison & Video Experts
Mike
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
