Question about Microsoft Windows XP Professional for PC
The screen switches off at its own whims and fancies.
After installation the computer seems to work perfectly. However the computer screen goes black and nothing responds. You just need to switch off the system and thereafter  restart the system.
Posted by Joeraj on
  • Joeraj Oct 23, 2007
    The system has following specifications:-
    celeron 1.1 processor.
    256 MB RAM.
    On board Display.
    40 GB HDD.
    All other std peripherals.
    Problem is felt running win xp esp after running MS Word.
    Once something is typed and the file is saved.
    Thereafter while scrolling up / down with arrow/ Page Up / Down, the video goges blank anytime.
    Pl help urgently.
  • samsailor Jan 27, 2008
    i have a 2.26 ghz pentium 4 pc . the pc stops after some time and reboots?????
Anonymous
  • 490 Answers
Plz ellaborate ur problem what r u installing a software or os if ur installing software then how much ram , hard disk& OS i there
Posted on Oct 22, 2007
arben pllana
  • 1,006 Answers
Just reinstall ( repair ) with original windows xp cd
Samsung SyncMaster 2232gw unstable
It seems from the begining you have had nothing but trouble, if under warranty return the item, because it will eventually fail, it is a matter of probability.
Apr 22, 2012 | Computers & Internet
Hi I have a problem of black screen with my hp pavilion dv400. Wheen I start my computer I can windows logo on the screen but just 1 or 2 second and the screen go black. But when I connect my computer...
Your laptop is probably outputting the video signal to the wrong monitor. When the screen goes black, try pressing the function key to switch the video back to the laptop screen. Refer to your laptop's manual on what key to press. Usually it is the Fn key and F4 at the same time for HP laptops.
Jul 06, 2011 | HP Pavilion dv4000 Notebook
My screen only displays after 4 /5 hrs
Try a different screensaver.
Also look in the display properties by simply right clicking the desktop and clicking properties.
Then locate power management.
the initial seems to be a bad screensaver judging by the 20 minutes, but the 4-5 hours seems to be a sleep mode that bypasses the screensaver issue.
Jul 23, 2009 | Computers & Internet
Black screen after fresh install xpmc 2005
Are you able to go windows safe mode if yes ... Start > Run > Msconfig > Ok
in the general tab you have option to seleect Normal Start up > Click on apply and ok and restart yiur computer that should work
Apr 09, 2009 | Microsoft Windows XP Media Center Edition...
Canon Powershot SD1000 Uploading Pics To Computer Problem
Since your two cameras have the same problem with the same computer, I would like to suggest you to connect those cameras to another computer. It looks like the problem is on the computer side.
Apr 04, 2009 | Canon PowerShot SD790 IS Digital Camera
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
My Dell Monitro goes black about 4 seconds after being turned on
Hi..there,
It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it.
Nov 12, 2008 | Computers & Internet
Black screen
Hi
did you get a solution for this problem as mine does exactly the same!
Thanks
[email protected]
Aug 22, 2008 | Relisys RLT1720 17" LCD Monitor
17" LCD Monitor - only works for a few seconds when turned on.
It seems to be an Inverter related problem in which backlight seems to be shiutting down.Is this monitor 3-4 years old???If so backlight of the panel could be an issue.
Feb 15, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Microsoft Windows XP Professional for PC Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Scoee Scoffer
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
