Question about Casio Fx-992s Scientific Calculator
How to make my degree button work? - Casio Fx-992s Scientific Calculator
Posted by jemie on
k24674
  • Casio Master
  • 8,091 Answers
I am sorry but the image does not show any Degree button.
To set the angle unit you have to press the Mode button twice before you arrive at the angle unit configuration. See the screen capture below.
how to make my degree button work? - 19e4a38e-b756-4043-8c53-8e9a94311416.png
Posted on Jan 16, 2014
My Viking professional refrigerator is stuck on 46 degrees refrigerator/ 6 degrees freezer. None of the buttons work. Is there a reset button?
press display on or (activate control) button first you should then be able to choose fridge or freezer and change set temp
after set will read actual temp 46 is a little high sounds like you have service issue
Jun 27, 2017 | Viking Refrigerators
How do i make the degree button of my fx992s work?
Jan 16, 2014 | Casio Fx-992s Scientific Calculator
My netbook got wet. Now the number buttons don't input one number they input three of the same number. My left mouse button doesn't click it is now working like the right mouse button. HELP???
I suspect that your net book has not dried out completely and has left a moisture trace on the membrane keyboard that is shorting to another trace. Heat the oven to 100 degrees (caution, do not go over 110 degrees), and place the net book in that 100 degree heat for a few hours. Hopefully any lingering moisture will evaporate and leave the key traces clean.
May 18, 2011 | Sylvania G-Netbook
HOW DO YOU PUT IN DEGREES AND MINUTES WHEN YOU ARE DOING TRIGONOMETRY?
The manual for your calculator can be found here: http://support.casio.com/pdf/004/fx-82ES_83ES.etc_Eng.pdf
To input a sexagesimal value [this is another word for Degrees/Minutes/Seconds], you need to follow the instructions on page E-21 of the manual.
  1. Type in the degrees
  2. Press the "degrees" button. This is located two buttons above the "8" button and looks like the degrees symbol and some commas
  3. Type in the minutes
  4. Press the "degrees" button again.
I hope this was helpful. Good luck!
Mar 02, 2011 | Casio FX83ES Scientific Calculator
I'm using the Casio fx-115ES model. When i try to put in 52 Degrees, 10 minutes, I dont seem to be able to do this. I key in the numbers 52 then hit the "degree, minutes seconds" button and i get the...
When entering the information it only shows the degree symbol. If you press enter or type inthe formula, then the answer will show the Degree, Minutes, and seconds. It seems to be the way it was program by Casio. It still seems to work fine for entering that information
Aug 03, 2010 | Casio FX-115ES Scientific Calculator
I have a Robert Shaw thermostat and it converted to celsius degrees. How do I program it for farenheit???
The thermostat is preset to display the temperature in degrees
Fahrenheit (US models) or degrees Celsius (Canadian models). The
temperature display can be changed. Press and hold both the
?° and ?°Ÿbutton for three seconds. The display will read F or C.
Release buttons. Press the ?° or ?°Ÿbutton to switch the display.
Jun 16, 2010 | Shaw Robert RS-9420 Thermostat
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Converting decimals to degrees on a casio fx-83es calcualtor
if you mean degrees like the degree/minute/second thing: lets say you have 24.12 there is a button that has a dot, and 3 commas (it's located next to the negative button) that will convert that number to degrees. input your decimal, press the equal sign, and then press that degree button and it will convert 24.12 to degrees, minutes, and seconds. the solution is 24 degrees, 7 minutes, and 12 seconds.
Jan 11, 2009 | Casio FX-115ES Scientific Calculator
Degrees of C
Hold down the recirc button and the (-) button or the (+) button below the temp display (on the left) - one of those combinations will change it. I don't think you have to have the system off for it to work, but I'm not positive - try it out and you'll see which way works.
Oct 21, 2008 | 1999 Audi A4
Casio Fx-992s Scientific Calculator Logo
48 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Carlo Barzo
Carlo Barzo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
