My display screen shows no picture, yet the camera still works. I decided to try to take a picture with flash and one without, to see the problem. The picture with the flash was alright, and the one without it was pitch black. Mind you, I took the pictures in a well lit room. I mean, even if my settings were not appropriate for the lighting the picture as taken in, there was supposed to be something there. I am using the Fujifilm Finepix s4300.
Could be your camera is still working, but some settings are messed up?
You could have turned off the display. In the menu with IMAGE DISP. Is used to save battery power.
Then try making pictures in the mode automatic. Because if you switched to scene like bright sunlight or snow your pictures can be very dark.
SOURCE: d70 no picture displays in monitor - all black
Check the 'monitor off' option... if you cant find it, open the manual in page 153... http://www.nikonusa.com/pdf/manuals/noprint/D70_en_noprint.pdf Good luck
SOURCE: Black LCD screen and viewfinder in photo take mode
Sony (who bought KM) will fix this for free. http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131
SOURCE: Nikon D50 LCD Display does not work
NatD, The D50 and indeed most SLR digital cameras [ I have a D40 ] does not allow you to take pictures using the LCD display ... this is by design, you are meant to use the viewfinder and the image you see through it is straight through the lens via a mirror block [ called a reflex pentamirror or prism ]. When the mirror is down such that you can see the image in the viewfinder it is obscuring the sensor [ the bit that takes the picture ] and when you take a shot the mirror lifts and the picture is recorded. Its this reason that DSLR's dont use the LCD to shoot, however there are a few now available that do let you do this, such as olympus, new panasonic one and higher end Nikon and Canon cameras. Hope this explains it without getting too detailed!
SOURCE: LCD Display Blank
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
SOURCE: No display at all. But able to take pictures with Canon A75
Sounds like you might have accidentally turned the display off. Turn on the camera and press the DISP button once on the back of your camera.
