Question about Hitachi RAS-09UH Air Conditioner
Remote control replacement
The unit it's not cooling,the remote is set wrong,how do you make it to run cold please.
Temp Control Problems
Hi, hild, first thing; stop the AC by remote controler, than select the fan option pressing by mode button and next start the AC, wait 8 minutes, if the unit still blows cold air, the thermistor has to be replaced. I hope this was helpful to you! success!
Jun 12, 2013 | LG Art Cool LA181CNW Split System Air...
Fridge is running but not cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 10, 2011 | Refrigerators
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
Jun 15, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
2006 Viking VUAR 141 bar fridge not cooling enough
The thermistor is looking for a very cold temperature before shuting off for the cycle defrost to work correctly. Thus if if shuts off early I would suspect the thermistor or the potentiometer. The pot is connected to terminals # 6 and 7 and should have a resistance over 90K-ohms when set to the coldest position. The thermsitor should have a resistance of 5.6K-ohms at 0 C and near 2.2 at 20 C. The control rarley fails but if it has been recently replaced the DIP switches (there are four of them) may be in the wrong position. If they are in question, try talking to technical customer service at Marvel (they made the unit). Their number is 800-223-3900. Your Viking VUAR 141 should be the same as their 60AR. The thermsitor is usually the most troublesome component but usually fails in the opposite way causing the unit to run too cold.
PS does the cooling fan shut off the same time as the compressor? if not, then the compressor overload is the issue...the the temperature control. If both shut off and on at the same time then you are on the right track.
Good Luck - Subdriver
Mar 22, 2010 | Refrigerators
Cannot set a/c to operate automatically
sound to be in heat modenow. If you are after the cool mode, then if you have a cool setting and a heat temp setting, Lower the heat to almost off and set the cool setting to 74 degrees. See if the outside coils get warm. Make sure you are off manualo and n auto. If it runs, give it some time and the tenp of the outside coil will rise and the inside will get cold. Food Luck
May 23, 2009 | Sanyo Split System Air Conditioner
Coleman 15k will not come on
Here is the troubleshooting guide for your unit. Hope this helps.
TROUBLE SHOOTING GUIDE
TROUBLESHOOTING
Symptom Remedy
1. Remote does not turn on system
- Check and replace remote batteries if the display fades while
any button is activated or no display is present. - Point remote towards IR receiver during transmission. 2. System does not turn on, no green LED & no beep
- Check wiring. (see "installation instruction")
- Check modular cable to receiver.
- Check diagnostic LED status in the upper unit control box.
3. System does not turn on even when receiver green LED is on.
- Low or over voltage condition, check diagnostic LED status in the upper unit control box.
4. Fan runs but no cold air.
- Evaporator temperature sensor reaches low limit, defrost mode.
5. System runs continuously in the cool mode
- Remote was set for "I feel" mode and is left in a heated environment (sun etc.)
6. System runs continuously in the heat mode
- Remote was set for "I feel" mode and is left in a cool environment
1. Diagnostic LED (green)
(Note: Located on the control board in the upper unit control box.)
a) The LED is on when the 12VDC is adequate and communications are
present.
b) The LED is flashing fast and steady when in the freeze mode. Evaporator has frozen and the freeze proctection switch is engaged.
c) The LED is flashing slow and steady when the delay on break timer is
activated.
d) The LED is flashing 1 cycle on and off for one second with high or low
12VDC. Check the incoming 12VDC power for OK.
e) The LED is flashing 2 cycles on and off for one second with a
communication problem. Problem with the control board in the unit and the remote.
Hope this helps.
Jeff
Rate me Please!!!
Jul 29, 2008 | Coleman Mach 15 Air Conditioner
Not cooling
- Check if there power is a supply by opening the door of fridge, if there is a light then there is a supply. But no light check the circuit breaker. Or try another outlet for testing. If your fridge is digital control and there is some error display, then reset the error.
- Check the thermostat setting if set to high cool, and check the compressor at the back of the unit if running, if not there is something wrong to your control or compressor itself, if the compressor is operating and no cool at all maybe your unit is out of refrigerant, please call a qualified technician.
Dec 31, 2007 | Kenmore 53642 / 53644 Side by Side...
Hitachi RAS-09UH Air Conditioner Logo
Top Hitachi Heating & Cooling Experts
Lawrence Oravetz
jws1013
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
