Question about Archos 604 WiFi Digital Media Player
Recovery Code 2 on Archos 604 WiFi
It was dropped and this message comes on.  When you click on repair nothing happens.  The screen etc seems to be intact, tried to take battery and re-install nothing happened.
Posted by punch on
  • 8 more comments
  • ajcars Dec 25, 2007
    Mines different, its the archos 404.The same meassage comes up though. the screen comes up when i turn it on. I need help
  • Anonymous Jan 17, 2008
    I have the same problem. Sent it to Archos and the tech wanted US$140 for repair the hard drive. I bought a new one for $200.
  • raybo12 Feb 19, 2008
    ARCHOS 604 WIFI WAS DROPPED,NOW DISPLAYS HDD RECOVERY
    USB ALSO FORMAT DISK,WHEN YOU CLICK ON THESE A MESSAGE APPEARS ROOT PARTITION INFO WRITE ERROR....MEDI FAILED
  • benniefieldj Oct 01, 2008
    recovery code 2 keeps coming up on my archos
  • al jones Nov 22, 2008
    same problem
  • Anonymous Dec 08, 2008
    MY ARCHOS 604 WAS ON THE BATRY REMOVED AND PUT IT BACK NOW DISPLAYS HDD RECOVERY
  • Anonymous Dec 13, 2008
    i dropped mine and the HDD recovery screen is the only one that comes on. it also shows usb/ format disc, however it is frozen and i con do nothing. it will not even connect to my computer.
  • Anonymous Apr 10, 2009
    recovery(code)
    sistem is damage
  • al jones May 11, 2010
    how do i fix it
Anonymous
    Problem Solver:
  • 6 Answers
The solution I found to reset the hard drive. Follow these procedures:
1. Remove the battery.
2. Unscrew the 2 screws on the right side of the battery compartment.
3. Loosen the 4 screws on the other side of the unit, but be very careful not to take them out, leave part of the screw in the hole, because if you don't, you'll have a hard time putting them back later as I found out. Now I have one loose screw on the bottom left.
4. Open the back cover carefully and make sure the 4 screws on the side are still intact. Adjust these screws if you have to but make sure they don't come all the way out. After opening the cover you'll see the hard drive and you'll probably see the connecting cable is loose. Lift out the hard drive and tighten the cable.
5. Replace the cover, tighten all the screws, and you are set.
After that, my 604wifi was able to start up normally and the recovery message is gone. A new problem now is the unit will turn off by itself after about 20 seconds. I suspected it was because of the loose screw, but I just don't have the time to fool with it now, well...future project.
Posted on Oct 01, 2008
  • Clint Copes May 19, 2012
    Wow. This fix was spot on. Only problem was I could not get the hard drive out w/o taking out the screws (didn't read variation instructions) and yes, I can't get 2 screws back in properly so i just put tape over them but my ARCHOS is back from the dead after years of collecting dust. Thank you so much.
Anonymous
    Problem Solver:
  • 6 Answers
Slight but important variation ...
Keep each screw with the original screw hold it came out of - it will greatly assist with replacement when needed. A magnetic screwdriver really helps here.
Looking from the back at all times:
1 - Remove battery
2 - Remove two screws to right of battery department
3 - Loosen (and you may well have to remove) the two screws on the now right face that are most rearwards (furthest from the LCD) - do NOT remove the two screws on the side nearest the LCD - this is unnecessary.
4 - *Gently* lift disk drive at top (opposite end from ribbon) and press in connector at the drive and on the board
5 - Replace the rear cover
6 - Carefully restart each screw - it is very easy to strip the threads in the hole.
7 - Replace battery and power up
It worked for me :-)
PK
Posted on Jan 10, 2009
  • Randy Crawford
    Randy Crawford Jan 11, 2020
    You are so right about stripping out the threads.
Anonymous
I had the same exact problem to the T. All i did was unscrew the tiny scrws next to the battery pack. Then took the back off made everything fit back tightly together than rescrewed the screws. It is working for now
Posted on Jul 06, 2008
Anonymous
    President:
  • 4,402 Answers
Download latest firmware
http://gofurygo.blogspot.com/2006/11/archos-604-wifi-firware-updated.html
Posted on Dec 10, 2007
Derrick Schultz
    Top Expert:
  • 11,405 Answers
Take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manuals
Posted on Jan 11, 2020
Wristy
  • 33 Answers
I followed the instructions and checked it was tight and put it back together and still had same problem.
So I opened it again and disconected the drive cable from the board and then reconnected it and put back together again.
When I tried it was working again, the cable must have not been in right.
So move the holding tab to release the cable and reinsert cable and move the tab back again so you know it's 100% connected.
The ports on the bottomw were not working either till I did this so if that is same for you then do as I did.
Posted on Mar 16, 2011
Anonymous
Kcwc or solution number 2 gave me a great start to solve my problem.  I had the red screen and the error (code 2).  However my harddisk was ticking like a bomb, but it was only doing tick, tick, tick.etc   Upon removing the lid of the hard drive the arm that reads the disc was stuck.  Gently I moved the arm away from the disc, and do not worry if you hear a snap.  I tested it with a USB to IDE/SATA Adapter and it ran exellent.
thanks kcwc!
Posted on Feb 24, 2009
Anonymous
The problem isn't downloading the firmware, the problem is that you can't load it to the archos!
Posted on Aug 09, 2008
Anonymous
So, I have this same problem and updating the firmware would be a GREAT solution IF you can get it to connect to your computer. You have to connect the USB from the menu and you did not get the option here. Customer service told me that it has to be sent in for repair.
Posted on Dec 20, 2007
Stuck on the ARCHOS Screen and it won't do any thing
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Jul 24, 2009 | Archos 704 WiFi Digital Media Player
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
Archos want work
Sounds like a disk problem. This might work for you ...
Power off the unit
[Optional step - remove battery and use a pen to push the reset button]
HOLD down the LOCK/TV-LCD button as you press the POWER button until the unit starts to come on.
You should should get options to recover the disk (try this first) or format the unit (try this last).
If that doesn't work i would follow the procedure of reseating the HDD connection - see solution for Recovery error code 2 problem.
Dec 25, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 wifi corrupted
Did you try ?
- Using the reset button located under the battery?
- Holding down the LCD button as you press POWER to start up the unit and trying one of the recovery options?
PK
Dec 19, 2008 | Archos 604 WiFi Digital Media Player
Archos Recovery (code 2)
Send them back to Archos if they are still under warranty. If not, you're out of luck because they'll charge you about US$140 to repair the hard drive + postage.
Sep 10, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 wifi
Are you sure the battery is charged? If so, try detach and retach the battery. Also try to attach to your computer via the usb cable and the 604 should turn on by itself, if nothing happens you need to send back to Archos for repair.
Jan 11, 2008 | Archos 604 WiFi Digital Media Player
Recovery (code 2)
I got the same message when I took out the hard drive. I'm sure this will void any warrant, but maybe you should open it up and make sure the hard drive ribbon is secure.
Nov 12, 2007 | Archos 604 Digital Media Player
HELP!
Can you hear HardDrive clicking?
Oct 03, 2007 | Archos 604 WiFi Digital Media Player
Archos 604 WiFi Digital Media Player Logo
Top Archos Audio Players & Recorders Experts
Harrie
Ngoro
ADMIN Canada
ADMIN Canada
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
