Hi I have drained the water from my machine, and have tried to remove the filter pump cover but it just turns and turns to no avail. I have also tried to use some gentle force . Thanks
OK..Got It! Your filter has disconnected from the Drain Pump. You need to have the machine's cover removed and re-attach the Filter back on to your Drain Pump! OKey...Dookie?
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
SOURCE: Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
SOURCE: Miele Novotronic Premier Plus washing machine drain filter
yes - use a rubber mallet to separate it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
