My laptop not supported drivers
SOURCE: need audio driver of compaq presario V6000
Here's a link to the audio drivers for the V6000. You will need to download both that are listed under audio.Don't forget to rate me (fixya). thanks
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1842078&lang=en
SOURCE: drivers for HP Compaq Presario V2000 laptop
pls send compaq notebook presario v2000 audio driver
SOURCE: audio driver
Compaq doesn't provide XP support for this model. Fortunately for you someone has done a lot of work to find drivers that will work.
Try the following drivers,
XP Drivers for CQ50-210US
NVidia Chipset,(install and reboot before other drivers), here
NVIDIA GeForce 8200
Nvidia ForceWare X 179.28 for Windows XP/2K 32bit, here
3-step process to install:
1. Download driver, double click and select extract,
2. Download modded INF and replace original INF in extracted folder,
3. Install & reboot.
or you may try other versions, joint their forum for further details
Note:
If you found errors (hopefully it has been fixed) when installing Nvidia 8200M G video driver, you need to force install the driver.
Pieter's INF forgot to put hardware ID for 8200M G, see this post.
MS-UAA (required with a reboot before Audio, Modem and nForce HDMI Audio drivers), here
Conexant SmartAudio 221 (fix microphone problem by forum user) here
How to install:
Unzip to a folder.run installer.
if it errors use Device Manager.
From Device Manager,right click "Audio Device on HD",choose Update driver,
No to connect, Install from a list or specific location,
Select Don't Search, I will choose the driver to install,
For the Hardware Type select 'Show All Devices'
Remove the check from "Show Compatible Hardware" and click on "Have Disk".
Next...browse to the unzipped folder and choose the "WiSVHe5.inf".
Ignore XP when it complains.
Reboot.
Conexant HDAUDIO Soft Data Fax Modem with SmartCP Driver, here
nForce HDMI Audio Driver, here
.Net Framework(required before Intel Wireless and HP Quick Launch Buttons), here
HP Quick Lauch Buttons, here
If you had Intel PRO/Wireless Driver, here
If you had Atheros Wireless driver, here
or if it does not work try here
If you had Broadcom Wireless, here
Realtek usb 2.0 Card reader, here
Synaptics Touchpad Driver, here
If you had Bluetooth, here
If you had for 7 unknown devices (buttons drivers), here
Installation --> right click machine.inf, choose install.
Good luck
The Vista Drivers are HERE
If you need any more help just let me know.
Please don't forget to rate my solution, FixYa
Thanks!
SOURCE: driver Compaq Presario C700 notebook
Only for windows xp steps........
u should always turn off automatic updates.......and install drivers it will be work fine..
I will give u all drivers link....go to hp.com and search it..
for modem -sp33442, for audio-sp35270, for sm bus controller-sp36492, for quick lounch sp38171, for UAA sp32395, for webcam sp37849, download all drivers and install it.
and install drivers follow these steps:
Open device manager and right-click on Audio device on High definition Audio Bus.
Select Install from a list of specific location (Advanced) Click Next
Select Don’t Search. I will choose the driver to install.
Select Sound, Game & video controller from the list of Hardware type
Click on Have Disk
Click on Browse and navigate to C:swsetupsp35270 and click on .ini file OK
Click Next
It will give you an update driver warning message. Click on yes.
It will start installing the driver
Click on Finish..
follow these steps to all drivers install.
wifi driver link:
http://www.atheros.cz/download.php?atheros=AR5007EG&system=1
good luck
