If you replaced the bd drive, this code means there is a problem accessing a file, that a file may be corrupted, and that in-order to resolve any corrupt files, you will need to go into recovery mode on ps3, and select restore file system, and that should fix that error. Holding power on ps3 until it shuts off, then holding power button until there is three beeps and let go will put you in recovery mode, make sure to have your controller hooked to your ps3 with a cord!
if it is a jailbroken ps3, try to update ur Manager, use Gaia, is the simplest one,
if not a jailbroken, try to uninstall the data of the game from ur hdd, but u will lose all ur saved data. and this method i didn't test it before, GOOD LUCK
Hello! Sorry to hear your playstation isn't working. There should be a Error code something like 80010006. It would greatly help if you could post it. Thanks.
Hey there. had the same issue as you did. Try resetting to your system defaults. This wont delete and game data or trophies. Will just reset your internet connection, resolution and things like that. Im not sure what setting was causing the error, but this fixed it for me
