Wires were cut so my friend tried to wire it directly to the same wires powering the outside motioin detector light, too much power!!!! camera wont' turn on now
SOURCE: Paradox 525D Motion Detector wiring up
nc c + - Y G Tmp Tmp
nc and c is relay output normally closed
+ and _ is 12vdc input
Y and G is bus connection
Tmp is tamper output also normally closed
SOURCE: rewire lorex SG6153P camera
I HAVE A SECURITY CAMERA GOT WITH THE WIRES RIPD FROM BACK OF IT 4 WITH WIRES 1 RED 1 WHITE 1 YELLOW AND 1 THICK BLACK WIRE HOW CAN I REWIRE IT?????
SOURCE: micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
SOURCE: video
I HAVE A MICROMARK CCTV ITS A SCART TYPE IT TELLS ME IN THE INSTRUCTIONS TO PUT THE SCARTLEAD INTO THE SCART ON THE TV WHICH I HAVE DONE I AM GETTING THE PICTURE OK BUT THERE IS NO SOUND ALL I GET IS A HUMMING SOUND JUST LIKE YOU HAVE NOT TUNE IN THE TV PROPERLY I CANNOT TUNE IN THE TV AS ITS ON THE AV SO CAN ANYONE TELL ME WHY I AM NOT GETTING THE SOUND WHEN IT TELLS ME WHEN I PUT IN THE SCART THE SOUND WILL BE PICKED UP . OR COULD IT BE THAT ITS A TV COMBI VIDEO
