Question about Lexmark X4270 All-In-One InkJet Printer
Scanning Problem I have a problem with my Lexmark 3 in 1. Each time I want to scan a document, it tells me to fix the apaper jam. I've looked all over but I can't find a piece of paper that was stuck in it.What do I do?
Posted by SokaRakos on
Geraldine Watts
    Sergeant:
  • 390 Answers
Did you open up the unit and check really closely near the carriage and the roller? Jams can be so very small!!!
Posted on Feb 12, 2008
Cannon fax l100 how can I fix this problem
Looks like a document jam as the paper rolled up under the scanner bed.
Do you have the manual for the unit?
It is on line at mypdfmanuals.com. Just google it!
1. Lift the document release lever.
If a multi-page document is loaded, remove
the entire document from the ADF.
2. Lift the paper stack cover and pull it out completely.
Make sure the back end of the cover does
not catch the front paper guide.
3. Lower the scanning platform in the document delivery slot (this is on ththe front of the machine - a small tab you push down.
4. Carefully!!! pull out the jammed document - do not wrench it out.
5. Lift the scanning platform back into place.
6. Inset the paper stack cover (that you took out earlier.
Found it here http://mypdfmanuals.com/dref/815752
Feb 11, 2013 | Office Equipment & Supplies
Lexmark Pro901 When scanning from document feed the machine seems to scan only a part of the page whilst cutting out the information at the bottom of the page.
Make sure to set the correct paper size when scanning from the ADF. If you're scanning a legal size document, set the paper size to legal.
If it doesn't work, try to reset the printer back to its factory settings:
1 From the home screen, touch Setup (wrench icon), and then touch Use Factory Defaults.
2 Touch Yes.
3 When prompted to set the initial settings of your printer, make your selections using the touch screen.
Oct 12, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
I was wondering how to scan more than one page at a time with the x7170. also is there any way to save the scanned document as a microsoft document?
The Lexmark X7170 printer can only scan one page at a time. However, it has the capability of scanning multiple pages using either the scanner glass or through the automatic document feeder. Refer to the Lexmark X7100 Series User's Guide for more information.
For your second question, Yes, you have an option to save your scanned file to a Microsoft document as long as the Lexmark OCR scan software is installed on your computer. The scan software is only available on the installation disc (not available as part of the downloadable driver on the Lexmark website).
May 12, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have a Fujitsu 4220c2 scanner and when scanning multiple documents it'll take one half half/quarter way through and get stuck. The pick roller and pad assembly have been replaced. What could be causing...
Thank you for contacting Fixya.
This error is detected when one of the followings occurs: (TWAIN Error-Paper jammed in the ADF - Code DS32002), Scanner panel error-U1
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner performs retry operation.) 2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Check the followings: 1.Scan condition - Transported length (L) before jam 2.ADF fixed size - scanning Approximately 450 mm 3.Long paper scanning -1.2 times of the specified value
If the imprinter is installed, paper jam can occur in the following case. If the scanner starts scanning when the imprinter cable (EXT cable) is not connected to the scanner, it does not rotate the imprinter, since it recognizes the imprinter not installed, which results in paper jam in the imprinter section.
Solution:
Remove the jammed document and close the ADF. When the error frequently occurs, refer to the followings:
1. Do the documents satisfy paper specification? Please read the operator guide for paper specification. 2. Have the documents been jogged? • Align the edge of documents for stable paper feeding. • Remove documents with crease or dog-ear. • Scanning different width of documents may cause skew and result in paper jam. 3. Is the Imprinter EXT cable correctly connected to the scanner? Check the cables. (only when the Imprinter is installed) 4. Clean rollers in ADF and Imprinter and see if the error is removed. (only when the Imprinter is installed) 5. Replace Pick roller and Pad ASY and see if the error is removed. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values shown, replace Pick roller or Pad ASY.
If the above do not help, then the issue could be caused by the followings:
6. Malfunction of TOP sensor. 7. Malfunction of Cover open sensor. 8. Faulty Scanner Control PCA.
If Imprinter is installed, then the issue could be caused by the followings:
1. Malfunction of Sensor OPB5 lever (only when the Imprinter is installed). 2. Malfunction of Motor LF if the imprinter roller does not rotate.(only when the Imprinter is installed). 3. Faulty Imprinter Control PCA. (only when the Imprinter is installed).
Hope the above information is helpful.Please revert if you have any doubt.
Regards,
TechSatya
Aug 10, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
A 2inch solid black horizontal band appears when scanning in the top 1/3 of document. same place all the time. it prints as scanned
You have to change the scanning mechanism under the glass. It is pretty trick, but after that it works great.
Apr 02, 2010 | Lexmark X1150 All-In-One InkJet Printer
I using lexmark x215 i dont have cd but i installed drivery from lexmark site now my printer is ok but i dont know how to scan my docunments bc i dont have scan software where i scan my docunments so tell...
  1. Check the connections between the two machines.
  2. Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
  3. Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
  4. Close the printer's document lid slowly so the document does not shift position.
  5. Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
  6. Push the scan button. You may have to do this on the printer itself or on your computer.
  7. Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
  8. Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.StepAccept the scan and save. Return the original document to a safe location.
Feb 24, 2010 | Lexmark X215 MFP All-In-One Laser Printer
Scaanner bed, where does it go?
Please follow the steps given below to scan a document:
1. Go to "Start," "All Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to".
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings" you can see change settings, which will affect the outcome of your scan.
Oct 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Directions for scanning to email.
If you're connected to a Windows PC, see User's Guide: http://www.lexmark.com/publications/pdfs/2007/2500/v3709407_en.pdf
Look for section with "Scanning documents or images for e-mailing"
May 14, 2009 | Lexmark X2500 All-In-One Printer
Lemark X1270 Error: Image Transferring Buffer Overflow
your's tech expert
Jeeth
Mar 28, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
49 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
