Eiki LC-X1100 Multimedia Projector Logo
S
ShoughT Posted on Jan 16, 2014
Eiki LC-X1100 Red Color Shift
When projecting an image blue and green colors match-up but red is a bit rebellious and is shifted a bit to the left. Without having taken it apart (yet) I don't know what is going on in there (picked up cheap from a uni. so no manual). Mostly just wanted to know if there is a "service code" I could work with or if I'm left to screwdrivers and prayers.
5 Related Answers
Anonymous
  • 6966 Answers
  • Posted on Jul 31, 2007
SOURCE: won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
projdoc
jasbo
  • 2239 Answers
  • Posted on Nov 18, 2009
SOURCE: Eiki LC-XG110 lamp going off
the lamp may be at the end of it's life.
projdoc
jasbo
  • 2239 Answers
SOURCE: EIKI LC-XNB4MS POWERS ON AND FANS START FOR 15 SECONDS AND THEN O
the lamp is near the end of it's life. time to replace it.
projdoc
jasbo
  • 2239 Answers
SOURCE: Eiki LC-X1100 Powers "off" after 10-15 minutes
even if the filters are clean, you will still need to blow the dust out of it with canned air. may be overheating. otherwise, sorry to say, it is the ballast.
projdoc
jasbo
  • 2239 Answers
SOURCE: Faded color display
replace the colorwheel.
What colors go in what spots
R & L are for the audio left and right and then Y is the green port and this carries the luma brightness signal, PB is the blue port that carries the signal between luma and blue and PR is the red port that carries the signal between luma and red. Your component cable should be color coded to match.
If you need further help, reach me via phone at https://www.6ya.com/expert/marc_162a3912222e83a4
Eiki lc x1100 multimedia projector lyrics are "shadowed" with multicolors
screen ,the color is ghost,
LCD panel is broken.you need a new one USD120
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Eiki LC-XC1 color problems
check all the optical parts around the blue lcd-panel, they might be darkened due to heat
I replaced the Convergence chip on my WS55511, and now the colors align properly, so there isn't a convergence problem. But the picture still isn't right. The colors shift towards red in the...
You have your input R G B / component wires hooked up incorrectly. The tv is detecting that and letting you know. disconnect and redo observe the color matching.
Color problems. last night instantly the color
2 things the cable could be faulty (unlikley)but worth a try
or your lamp is starting to fail
2helpful
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
2helpful
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
7helpful
2answers
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Toshiba Rear Projection TV
In the videomenu theres an option called convergence. you can shift blue and red color arround the green on, hopefully solving you're problem.
Good Luck
Top Eiki Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
